Old 07-18-2013, 07:13 AM   #1
xrcr
Cargo light
84 cab. Cannot remember how this was secured. I cannot find any bolts,clips or inserts in my pile of parts that make any sense. Any help is appreciated.
xrcr is offline   Reply With Quote
Old 07-18-2013, 08:22 PM   #2
bigd65
bigd65's Avatar
Re: Cargo light
I shaved mine ..
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 07-18-2013, 09:36 PM   #3
77 Sport
77 Sport's Avatar
Re: Cargo light
I went to LMC's online catalog, page 180, and it shows a drawing of the nuts. The nuts are encased in a rubber gromet and, I think, pushed into the holes in the cab from the inside. I'm trying to remember because I don't have a cargo lamp on my 77 but I pulled one from a junk yard about a year ago.
77 Sport is offline   Reply With Quote
Old 07-18-2013, 11:27 PM   #4
hrc200x
Re: Cargo light
77 sport is correct from what i can remember... they either push through the holes from the inside or are inserted from the outside and they pinch in the hole when the mount screw is tightened but I think it is the first way. I've tried removing the nuts from old cabs with not much luck, end up ruining rubber so had to buy new from LMC.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 07-19-2013, 03:00 AM   #5
bilfman
bilfman's Avatar
Re: Cargo light
The rubber grommets are a pain. I just made my own set up by welding a piece of coat hanger to some 1/4 inch nuts. I just made the hanger wire about 1/2 inch longer then the cab holes and welded them to the nuts. Bend the wire until the nuts/holes line up and it holds and locks the nuts. Can take a bit of lining up but removal is a snap after that!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 07-19-2013, 07:17 AM   #6
xrcr
Re: Cargo light
Thanks for the info. Cant quite wrap my head around the coat hanger thing yet but it sounds promising. Can always go the insert way I suppose.
HTML Code:
I shaved mine
TMI Brother
xrcr
