Old 07-21-2013, 05:04 PM   #1
AJLChase
AJLChase's Avatar
Exhaust Manifold/Header for lowered 67
Just curious if you guys would have a suggestion as to which exhaust manifold/header would be best for my application.
I have a 67 long box with at 327 that has 2.5 drop spindles and 1 drop spring on the front end currently. Originally I had close to 5" drop up front but I was getting too much street grinding/rubbing onto my under carriage.
My main problem is that the stock manifold's exhaust is a 2-in-1 design and the steep angle causes that part of the exhaust to hit/grind on just about everything.
Right now I have a second hand dual exhaust setup, which I'm looking to replace the stock setup that's currently on the truck, which looks like each one angles up towards the motor at a 45 degree. To keep things cheap, what headers should I use to hug the motor as well as keep the exhaust from hanging so low.
No pictures, so hopefully I described my needs well enough!
AJLChase is offline   Reply With Quote
