Old 07-21-2013, 08:25 PM   #1
missionstreettattoo
missionstreettattoo's Avatar
1968 c10 brake proportioning valve
is it possible that this is the reason i cannot get any pedal to my brakes? i have bled three brake fluid bottles through and it still goes to the floor. i got a master cylinder bleeding kit and di that. still to the floor. the shoes are adjusted out properly. the proportioning valve is the only thing left.
missionstreettattoo is offline   Reply With Quote
Old 07-21-2013, 08:31 PM   #2
missionstreettattoo
Re: 1968 c10 brake proportioning valve
why does my truck with drum brakes even have what is called a disc brake proportioning valve? and can i just bypass this?
Old 07-21-2013, 09:47 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
They don't.
Drum brake trucks just have a distribution block.
Keith
Convert to disc brakes.
Old 07-21-2013, 10:44 PM   #4
missionstreettattoo
this is what is below my master cylinder. I have drum brakes all the way around. i can bypass this right?
Old 07-22-2013, 11:20 AM   #5
missionstreettattoo
so is this something i can remove and connect brake lines directly to the master cylinder? any thoughts? this is my last place to look in finding why i cannot get anything but a saft pedal. straight to the floor. no matter what i have done.
Old 07-22-2013, 11:38 AM   #6
lolife99
lolife99's Avatar
You can remove it,... but you will lose your brake light switch.
You may have a bad M/C.
I would bench bleed it and try again.
Keith
Old 07-22-2013, 11:59 AM   #7
Ridgeclimber
Is your master cylinder new? It's hard to tell from the picture. If the master cylinder is used, maybe the cup seals in the master cylinder could be leaking by causing the pedal to go down. If the master cylinder is new. Start by bench bleeding it, slowly. Don't pump it hard and fast. If there is air in it you could break up the air and air rate the fluid. Then instal the cylinder and start by bleeding the right rear wheel first. Then left rear, then right front then left front. Again pump the pedal slowly and don't turn the air and fluid into foam. Good luck.
Ridgeclimber is offline   Reply With Quote
Old 07-22-2013, 12:08 PM   #8
Mister-B
Get a new master cylinder for $17, and bench bleed it. Your current one has probably gone bad
Mister-B is offline   Reply With Quote
Old 07-22-2013, 01:06 PM   #9
cdowns
cdowns's Avatar
i have found buying and reading a factory service manual for a particular vehicle can help you know what you have and how to fix it
Old 07-22-2013, 01:39 PM   #10
Steve Cole
I have never seen bleeder screws ON the master cylinder before! WOW! Are they tight when your pumping? You did put the cap back on, right? Sounds dumb but it could happen. Do you EVER get a tight pedal? or is it always soft?
Steve Cole is offline   Reply With Quote
Old 07-22-2013, 02:42 PM   #11
Ridgeclimber
Is the pedal just low towards the floor or is it spongy. That is two different problems. If the pedal is low could be brake shoes out of adjustment or be shoes not seated into the drums. If the pedal is hard then creaps to the floor it could be the master cylinder leaking internally. If the pedal is just spongy then it could be air in the system. Just another thing to consider.
Old 07-22-2013, 05:07 PM   #12
missionstreettattoo
if it sits any time at all, the pedal goes straight to the floor, after a few pumps, there is pedal again. the master cylinder was bought new at oreillys a year ago and installed then. only in the last month have i gotten all the lines and things replaced and hooked up.
Old 07-22-2013, 05:07 PM   #13
missionstreettattoo
so the bleeder valves on the mc are strange?
Old 07-22-2013, 05:38 PM   #14
missionstreettattoo
well the truck never ran. it was parked the whole year ive had it,but i guess my next step will be a different master cylinder, just do it and see what happens.
Old 07-22-2013, 05:42 PM   #15
Mister-B
And don't install the new MC without bench bleeding it first, or you'll have issues still
