78 heavy half ton
So I was finally able to track down more info on my c15. The paper work says its a heavy half ton. So I'm wondering if I can use 1/2 and 3/4 ton front and rear suspension shocks, leaf springs, ect. I think it's got 8 leafs in rear really would like to use the 4 or 6 leafs there a little cheaper and if all of it would be a bolt in installation. And now I'm wondering what the other differences would be if any or does it just mean the suspension is different?
Posted via Mobile Device |
#2 | |
Re: 78 heavy half ton
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
So could I move the position of the hangers? and is that a something that could be done with drilling a couple more holes and sliding them in more
The wholes should already be in the frame. You will have to cut/drill out the factory rivets for the shackle mounts to move them back. Use grade 8 bolts when re-installing the mounts further back.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#5 | |
Essentially the "heavy half" trucks are a 3/4 ton truck with 5 lug wheels.
They have the heavier springs and bigger brakes, just not 8 lug axles/rotors
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Thanks, sounds like a fun little project ill definitely start Friday night. I don't tow or haul any big loads so I think the 4 leaf will work great well I hope lol. Would you think it's a good idea to replace the shackles or keep originals and just clean up
![]() Join Date: Oct 2006
not quite....The frame is still a 1/2t frame. Just went through this.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
What are you talking about the 4 leafs are 1/2 ton so I'm putting them on a 1/2 ton frame I don't see the issue with that
The response was not meant for you,sorry. You have the right plan.
Ok thanks then Friday it is . Sorry for the snap
Yeah, the large springs suck butt ride wise. I've got them on my 77. I would put 4 leaf packs in but I'm too lazy to mess with the rivets.
i wanted to swap mine for the smaller ones too. It rides much better now after the flip. Since your planning a flip too, just leave them you wont regret it...
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#13 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
driving is in my blood
Exactly what I was thinking. Why mess around with new springs and moving shackles when there is a much easier option that will also soften the ride.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#15 |
Will removing the s couple leafs lower the truck as well I was going with the 4 leaf because of price. my leafs on there now are shot thinking of replacing them
#16 |
Mine actually rides VERY nice.
#17 |
Yea the ride sucks now hopefully when I put the 4 leaf it will be much smoother ride. As for the front suspension is it basically the same 1/2 and 3/4 ton I heard just the brakes are bigger but everything else is the same
#18 |
1/2 came w 1,475 or 1,550 coils. HH 1,625 or 1,700 (GM info)
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. |
#19 |
should. I still would NOT move the spring hangers no matter what.
#20 |
Would moving the hangers compromise any integrity or stability in the trucks driving the way it rides. I'm asking because if I move the hangers and put new 4 leaf pack I don't want any damage to my baby lol
#21 | |
Just replace the rivets that you cut loose with grade 8 bolts. K
#22 |
So when I put the 4 leaf pack on will it lower the truck in back. And if so won't I have to do the front at the same time. Hoping it doesn't lower to much
#23 |
The amount of lowering will only be the thickness of the leafs you are removing. If you do every other one as directed you should not see anything significant because the curve in the main leaf has not changed. I would go with removing the leafs and not moving the hangers. Dont forget new bushings in all your holes while you have it apart.
1977 K10 6ft Stepside L6 1978 C10 8ft Stepside 400 1980 C10 8ft Widebox with Uncle L6 1986 K35 Not a dually 350; 79 K20 Stripped 1973 and 1976 Chevy Truck Trailers 1995 Impala SS LT1 ![]() |
#24 |
The longer 56" springs,with less leafs will have a softer ride than the std 52" springs. I would just remove every other spring(total of 3 at at first) and see how she rides then.
#25 |
I will add, if you have the extra heavy duty front coil springs (1050 lb/in I believe), its going to feel unbalanced with the now soft springs in the rear and the "firm" springs up front.
Alex. |
