Old 07-25-2013, 12:53 PM   #1
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Cutting cab for driveshaft
I'm in the process of finishing my truck after a step notch install and was wondering if anyone has pictures or has done a 1 piece drive shaft instead of a 2 piece? I know everyone likes to go with 2 piece but I was wondering what would need to be cut for a one piece? I don't mind cutting..or if I go with 2 piece is it worth buying a used or just have a shop make me one. Thanks :devil
GGinferno is offline   Reply With Quote
Old 07-25-2013, 03:48 PM   #2
Budman56
Budman56's Avatar
Re: Cutting cab for driveshaft
First off do you have a long bed or short bed? and what year truck? are you going to lower it? all these question will have to be answered before we can give you any suggestions. It looks like you said step notch so I would assume you have lowered the truck?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 07-26-2013, 12:02 AM   #3
GGinferno
GGinferno's Avatar
Here what i have 66 short bed,step notch with poterbuilt 3" trailing arms stock crossmember..not afraid to cut and rather stick with a one piece.
Old 07-26-2013, 02:06 AM   #4
GGinferno
GGinferno's Avatar
Old 07-26-2013, 06:07 AM   #5
DURG
DURG's Avatar
I have the Porterbuilt Touring setup with rear 4 link and a 5" step notch. Short bed '65 C-10. I just ordered a 1 piece aluminum 3.5" diameter shaft and I don't have to cut the cab. This is with my motor sitting in the Porterbuilt crossmember and using their tubular tranny crossmember so I don't know high my motor and tranny sits in the frame compared to yours. I had Nate build me a set of motor mounts that allowed my motor to sit about 3/4" lower than normal in that front crossmember. Hope this helps.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 07-25-2013, 08:09 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I had a cross member notched to lower the rear and miss the driveshaft, but the cab was way out of the way.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-25-2013, 11:59 PM   #7
GGinferno
GGinferno's Avatar
Was that with step notch? The crossmember would need to cut and the cab did look high?? Lets see if someone has some pictures. Thanks
Old 07-26-2013, 06:20 AM   #8
61_FL_Apache
Who Me?
This was from my 65
Steve
2001 Blazer 4D 2WD
Old 07-26-2013, 01:18 PM   #9
rideblue00
rideblue00's Avatar
Excuse my ignorance, whats a step notch?
rideblue00 is offline   Reply With Quote
