07-27-2013, 04:47 PM | #1 |
Door striker alignment
Doing a frame off trying to get doors to shut properly having trouble aligning strikers can any one help with suggestions. Many thanks.
Posted via Mobile Device |
07-27-2013, 07:10 PM | #2 |
Re: Door striker alignment
First I would line the door up without the striker. Get all your lines and gaps like you want them first. Then you can install the striker. Install it snug where you think it will close and try it slowly. The slots in the door jam allow for movement to line it up. just make small changes each time. I like to get the up and down alignment first the just tap the striker in and out to get it to close. If you are to high it will lift the door and not close properly. Remember to shim the striker to align.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
07-28-2013, 06:45 AM | #3 |
1969 Custom 30 wrecker
The above poster nailed it.
Just make sure you make very small adjustments. A little goes a long way with these.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
