Old 07-28-2013, 04:30 PM   #1
Lil Ape
Truck idles high in park/neutral
I've got an '82 with a 350 sb with a eldelbrock rpm cam and a 670 holley street avenger carb. For some season, my truck will idle higher when it is in park or neutral. and normal when in gear. Is this normal? I don't have a tach hooked up yet so I don't know what rpms it's at. This was a freshly built engine with maybe 60 miles on it.
Lil Ape is offline   Reply With Quote
Old 07-28-2013, 05:29 PM   #2
Damon23
Damon23's Avatar
Re: Truck idles high in park/neutral
They do idle up when not in gear cause here is no load on the motor. Mine idles at 575 but jumps up to about 900 not in gear.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 07-28-2013, 05:55 PM   #3
geezer#99
geezer#99's Avatar
Advance your timing to 14-16 degrees, then slow your idle down. Shouldn't be that big a drop. Maybe 150 rpm at the most.
Old 07-28-2013, 07:26 PM   #4
LONGHAIR
How big is that cam? It make like a looser torque converter. That can make a bigger drop when going into gear.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-28-2013, 07:47 PM   #5
cedens
cedens's Avatar
did you check the fast idle adjustment on your carb, that normally does the trick
cedens is offline   Reply With Quote
Old 07-28-2013, 09:23 PM   #6
cedens
cedens's Avatar
I forgot to add is the a/c kicking on, that will cause a higher idle.
Old 07-30-2013, 12:35 PM   #7
Lil Ape
It's a edelbrock performer rpm cam, with a 3k stall converter. Which is what edelbrock recommended with the cam. Also no a/c on the truck. And I really haven't messed witj the carb much, other than the curb idle screw.
