07-30-2013, 08:52 PM | #1 |
Balljoint torques?
Anybody know the torque specs for 85 3/4 ton C20 ball joints, upper and lower on the ball nuts , and upper for the 4 mounting bolts to upper control arm. Trying to get my disc conversion done, can't find the specs. Mounting on my 68 C20. Thanks. Jim
07-30-2013, 09:20 PM | #2 |
Re: Balljoint torques?
If you want, here is a link for the square body service manuals that cover most years except 85. He does however have both 84 and 86 along with many others.
http://67-72chevytrucks.com/vboard/s...d.php?t=545416 The 67-72 manuals are here. http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-30-2013, 09:50 PM | #3 |
MOOG UBJ:
1/4" 10-14 ft.-lbs. 5/16" 14-19 ft.-lbs. 1/2" 55-65 ft.-lbs. 5/8" 75-90 ft.-lbs. 9/16" 60-80 ft.lbs. MOOG LBJ: 7/16" and 12 MM 40-55 Ft. Lbs. 1/2" 55-65 Ft. Lbs. 9/16" and 14 MM 65-75 Ft. Lbs.(except Aluminum knuckle). 5/8" and 16 MM 75-90 Ft. Lbs. 11/16" 90-100 Ft. Lbs. 3/4" 100-120 Ft Lbs. 18 MM 100-120 Ft. Lbs. Vehicles with aluminum knuckle 50 Ft. Lbs. |
