Old 08-01-2013, 02:29 AM   #1
lowesguy
lowesguy's Avatar
They gave me the wrong belts! again
Decided to replace all 3 belts on my 78 350CI,did this 10 years ago and the parts place did the same thing! for some reason all the part places get it wrong!why,any ways the old belts still have life in them and the truck just drives in the town here,no hi speed driving,did change the coolant after 5 years ,so not all was lost! now just need to return those new belts for some gas money!Bahahahah!
Thanks John!
lowesguy is offline   Reply With Quote
Old 08-01-2013, 07:10 AM   #2
lazypineapple
lazypineapple's Avatar
Re: They gave me the wrong belts! again
the part number is on the belts
dont leave the store without matching the numbers,
your water pump belt looks like it sits in the pully groove to low.
lazypineapple is offline   Reply With Quote
Old 08-01-2013, 11:30 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Vee belt part numbers are typically 5 digit.
The first two numbers are the belt width
The last three is length
Example 15445
The 15 is the width. 445 means its 44.5 inches long.
Say you needed a belt an inch shorter. You'd ask for a 15435. Four inches longer would be a 15495 etc. knowing this, you can tailed your exact lengths to get them adjusted to suit you.
Tx Firefighter is offline   Reply With Quote
Old 08-01-2013, 12:12 PM   #4
Desert1957
Desert1957's Avatar
Originally Posted by tx firefighter View Post
vee belt part numbers are typically 5 digit.
the last three is length
example 15445
the 15 is the width. 445 means its 44.5 inches long.
Say you needed a belt an inch shorter. You'd ask for a 15435. Four inches longer would be a 15495 etc. Knowing this, you can tailed your exact lengths to get them adjusted to suit you.
posted via mobile device
^^^^^^^^^^^^^^^^^^^^^this^^^^^^^^^^^^^^^^^^^^
Desert1957 is offline   Reply With Quote
Old 08-01-2013, 12:17 PM   #5
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Along with the belt numbers as mentioned above, I've always practiced just taking the belt in with me and making damn sure it matches. IF it doesn't match, they can march their *ss back to the hooks and find the right one. That's what I did at O'reilly, no reason they can't.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 08-01-2013, 02:55 PM   #6
lowesguy
lowesguy's Avatar
I've always had issues with the belts on this truck,someone added A/C to it a long time ago and added brackets and stuff that messed the whole equation up.
the pulleys need to be balanced or replaced,while running the whole mess is unbalanced,even the harmonic balancer,oil pressure is fine 60psi, so don't think the main bearing are an issue?
Thanks John!
