08-01-2013, 08:48 PM | #1 |
Rough Country Lift
So i bought a lift for my 76 3/4 ton. Everything went on fine. Front lift springs, rear blocks, rear extended brake hose. Then I get to the front hoses. They wont fit. They are the right length, but the banjo bolt for the caliper is too big to go through the new fitting. I went to autozone and had them pull me a replacement caliper and hose to verify that mine were correct. Turns out they are and the stock hose has a larger opening then the one from Rough Country. I call rough country and they dont know what happened. Maybe a faulty hose build. So they send me new ones and they still dont fit. I am %100 sure its a dana 44. Im %90 sure that they are stock correct axles front and back. I just dont know why they dont fit. Does anyone have any suggestions???? Any other problems like this from Rough Country?
08-02-2013, 08:54 AM | #2 |
Re: Rough Country Lift
10 bolt and Dana 44 took different sized banjo bolts.
If I had to guess, I think the Dana 44 took 7/16 size and the Corp10 (and Dana 60) took 10mm bolts. The axles may be stock, but the calipers might be swapped. |
08-02-2013, 10:07 AM | #3 |
Pictures of axle and wrong parts.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-04-2013, 09:05 PM | #4 |
