Old 08-02-2013, 12:14 AM   #1
alyslo
Big block 454 4x4 nv4500 mechanical clutch linkage
Working on a 1964 K20 4x4. Trying to set up my clutch linkage from the frame to the block. Its a nv4500 and a big block 454ci with mechanical linkage. Does anyone have some ideas or pictures of a similar set up so I can get the ball rolling? Thanks!
alyslo is offline   Reply With Quote
Old 08-02-2013, 01:39 AM   #2
Captainfab
60-66 Nut
Re: Big block 454 4x4 nv4500 mechanical clutch linkage
The NV4500's did not come from the factory with a mechanical clutch linkage, they were all hydraulic. If you want to run a mechanical clutch linkage, Advance adapters sells a manual clutch bellhousing for the NV4500. I have looked at fabricating a mechanical clutch linkage for a manual trans truck with a big block, but it looks like a huge PITA to me. Plus not everyone uses the same motor mounts, or installs them in the same location, when converting to a big block. Personally, with a big block, I would just convert the truck to a hydraulic clutch, it will be much easier. That is what I plan on doing with the 2 trucks of mine that I will be installing a NV4500. I sell a hydraulic clutch conversion, if you are interested.
Old 08-02-2013, 02:54 AM   #3
padresag
here is an advanced bellhousing
ron
padresag is offline   Reply With Quote
Old 08-03-2013, 02:12 PM   #4
alyslo
Thanks for the reply. I already have the adv adap mech bell housing. I May be interested in your hydraulic conversion. Do you have any pictures of it? ideally I would like to figure out how to do the mechanical set up and make it look sanitary but I'm out of ideas. Also is this a picture of your project?
Thanks!
Old 08-03-2013, 11:57 PM   #5
RockTonka
RockTonka's Avatar
Kinda doing the same thing...BBC, 4500, 205 under a 58. I'm gonna run a hydraulic set-up...made a bracket to hold the slave where I wanted it. Pretty straight forward this way.
Drive train in chassis...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 08-04-2013, 01:26 AM   #6
vinco
This is just bad to the bone!!! Looks awesome!
vinco is offline   Reply With Quote
Old 08-04-2013, 01:45 AM   #7
franken
Yup.
Nice clean parts too. Not like the groady old crap I have to work with
I want that TC brake. Then I could use the 14 bolt in the back w/o an E-brake.
Old 08-04-2013, 08:36 PM   #8
RockTonka
RockTonka's Avatar
Exactly
My build thread
Old 08-06-2013, 09:00 PM   #9
alyslo
After seeing these pictures I have been talked into the hydraulic set up. Slave bracket looks great along with the whole project. Interested in making another slave bracket??
Old 08-04-2013, 12:31 AM   #10
Captainfab
60-66 Nut
I don't have any pics of the '63-'66 conversion parts, but it is basically the same as what I sell for the '60-'62's. There are just a couple modifications to it to fit the '63-'66 better.
The biggest issue you will have with a mechanical clutch linkage and a big block, is making it work with your headers/manifolds.
No that is not a pic of my project, that is another members project.
Thanks!
Old 08-06-2013, 09:04 PM   #11
alyslo
Captainfab, Looks like I will need to order a booster bracket kit from you with the clutch master tab . Looks great. Thanks to all for the info and the pics are always a plus.
Old 08-04-2013, 12:08 AM   #12
franken
Just guessing, but I'd locate the engine and trans in the frame, then locate the Z-bar vased on where the ball stud is in the engine.
From there, work out the rod from the Z-bar to the clutch fork, and to the rod coming from the clutch pedal.
I'm working on an NV4500/NP205 combo for my 72. I parted a Suburban to get the 205, AA bellhousing, hydraulic master and slave, etc.
Old 09-21-2014, 09:28 PM   #13
Auctioneerhere
This thread just helped me out a bunch.
What did you rob the slave cyl off? another Chevrolet?
Thanks!
Auctioneerhere is offline   Reply With Quote
