Old 08-02-2013, 07:28 PM   #1
Bean Counter
Need some advice on gas tank!
Has anyone used the poly replacement tank on their truck? I'm in the test-fitting stage and I don't like where the filler neck is positioned (see the pic). I had planned on using an in-bed filler neck. As the filler tube is currently positioned, it goes almost directly through the sill which I've already notched. Was curious if anyone else had run into this problem and what they did. Did you just "go with it" or other?
I would really like to relocate the filler neck just slightly forward but don't know how to seal the current opening and safely make a new one. Any suggestions - or laughs - would be appreciated!
Thanks,
David
David
Next project - 1953 Chevy 150 2 Dr Sedan.
https://www.chevytalk.org/fusionbb/s...hp?tid/355913/
Bean Counter is offline   Reply With Quote
