Old 08-02-2013, 11:28 PM   #1
Steve Cole
Anyone running this shutoff valve?
I don't know what it is called, but is there some type of shutoff valve that goes in line between the water pump and the heater core for non AC trucks? I am looking to be able to shut off the hot water that would normally circulate through the heater core in the summer. I don't need any additional radiant heat in the cab when it's 100 degrees outside.
What's it called and where can I get one?
Steve Cole is offline   Reply With Quote
Old 08-03-2013, 12:13 AM   #2
muckyp
muckyp's Avatar
Re: Anyone running this shutoff valve?
I've always referred to that as a heater core bypass valve. Old Air offers several.
http://www.oldairproducts.com/catalo..._33000000.html
http://www.oldairproducts.com/catalo...ve-p-3667.html
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 08-03-2013, 08:13 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Anyone running this shutoff valve?
U can buy them at local auto stores. Manual shut off's. Just close it off during the summer. This is mine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-03-2013, 08:44 AM   #4
Steve Cole
Thanks guys!
Old 08-03-2013, 01:50 PM   #5
mike88a
mike88a's Avatar
Okay stupid question. Which line do you put it on? Or do you need two of them?
mike88a is offline   Reply With Quote
Old 08-03-2013, 04:10 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Anyone running this shutoff valve?
Only one per vehicle and it will stop circulation to the heater core. Most are 3/4" nipples so it's the 3/4" line but either or will do if it fits the hose.
Old 08-03-2013, 05:32 PM   #7
Tinkermc
the valves were at one time supplied with the ever popular flush kit.
Tinkermc is offline   Reply With Quote
