Old 08-06-2013, 10:24 PM   #1
D-man313
D-man313's Avatar
64 c10 bare rear end.
I just picked up a 64 fleetside shortbed project. The rear end housing has been sandblasted and painted by the PO. It is just the bare housing, No internals. What would I have to do to get 5X4 and 3/4 Bolt pattern axles with say a 3.73 posi center section? Can I go to the local junkyard and pull the axles and center section out of something with a 12 bolt the same width? Order something aftermarket? Are all 12 bolt housings the same? All 12 bolt centers the same? Where would I measure from to get an idea of what I need to look for at the junk yard?
David
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 08-06-2013, 11:43 PM   #2
D-man313
D-man313's Avatar
Re: 64 c10 bare rear end.
Basically to simplify. Can I go get a 12 bolt the same width and bolt the whole unit in? Would it be cheaper to pull the internals and put them in my housing?
Old 08-07-2013, 12:20 AM   #3
Captainfab
60-66 Nut
All the truck 12 bolt internals will be the same. As for the axles you will not find what you are looking for in a wrecking yard. You will have to have a set of axles made for your housing. If that is an original '63 to early '70 12 bolt truck housing, it should be about 57" +/- backing plate flange to backing plate flange. The late '70 to '82 12 bolt housings will be 1.5" wider. I do know that Moser can make the axles you want. Then you will have to figure out the brakes. I will possibly have a rear disc brake bracket set in a week or so, that will work with what you are doing.
Old 08-07-2013, 11:00 AM   #4
D-man313
D-man313's Avatar
I know I can get custom axels made and buy a new center section, but don't want to spend that kind of money. If I found the right one, I could buy a complete rear end from the junk yard for less then what a new center section from moser would be.
Old 08-07-2013, 11:49 AM   #5
jayoldschool
Moderator
Buy a complete later 5x5 rear and redrill the axles/drums for the 5x4.75 pattern.
jayoldschool is offline   Reply With Quote
Old 08-07-2013, 01:46 PM   #6
D-man313
D-man313's Avatar
What year later rears fit? Does anything else have to be done besides just redrilling the axles and drums?
