Old 07-03-2003, 07:56 PM   #1
Boones
How hard is it to shorten a long bed
Found a nice 72 Cheyenne Long bed with AC here locally but I want a short bed. I have heard there are kits (templates) for cutting the frame and I know you can buy the bed sides..
As I see it the following must be done, am I missing anything
cut, shorten frame, reweld
shorten the driveshaft, brake lines and ebrake cables
disassemble the bed, cut floor down, reassemble bed
I know its not that simple but have to ask
Has anyone attempted this and how tough it is really....
Thanks Boones
Boones is offline   Reply With Quote
Old 07-03-2003, 11:28 PM   #2
Smooth68
Smooth68's Avatar
The search is down, but I posted a link to a site that shows the process of cutting down a long bed. As for the frame, you've got it figured out sounds like.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 07-03-2003, 11:31 PM   #3
krue
Designated A-hole!
krue's Avatar
You should be able to beat the woods around there and find a short bed, unless they crushed them all since I was stationed there!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-04-2003, 10:38 AM   #4
Boones
Thanks for the info. I guess I will start digging thru the old posts
Old 07-05-2003, 04:02 PM   #5
iluvmy72
You will have to remove the cab to do it because that's where the only strait section is.
iluvmy72 is offline   Reply With Quote
Old 07-05-2003, 10:36 PM   #6
Gene
Gene's Avatar
You dont have to remove the cab all you have to do is support the cab and remove the rivets on the rear cab support while you remove 12 inches fron the frame under the cab. After you remove the 12 inches you simply roll the rear section froward and reweld the frame along with your frame supports. I shortened my longbed but I found a suitable donor bed to use instead of shortening my longbed. If you have any questions pm me I will be happy to give you some tips.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 07-05-2003, 11:10 PM   #7
iluvmy72
Gene
Gene......that's what a friend of mine thought....he almost died when the gas tank exploded......welding 6 inches from a gas tak isn't a good idea......but it safer to take off the whole cab
