08-13-2013, 10:12 PM | #1 |
Cylinder head repair ?
So at work I had to pull the driver side head to attempt to remove a broken exhaust manifold bolt... The bolt at the very rear of the head.. #7 cyl. So I get the head out and try to get the broken bolt out using Snap on screw extractors...No luck. I didn't take an after pic but its not pretty. The drill bit went kinda sideways. My question is : How big a helicoil can I put in to finish this without damaging the head or hitting water jackets ?
72 C20 Longbed 05 1500 Z71 |
08-14-2013, 12:55 AM | #2 |
Fabricate till you "puke"
Re: Cylinder head repair ?
I cannot answer your ? But will ask you 1....the 8 mm bolt is basically 5/16 ", is there enough material that can you drill & tap to 3/8 "? Just a thought, you might peel less material that way....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-14-2013, 01:21 AM | #3 |
I think there should be enough material there. I guess I will find out tomorrow Thanks crazylonghorn !
08-15-2013, 12:23 AM | #4 |
Well good news ! I was able to helicoil the head and use the GM 8mmx1.25bolts for the exhaust manifold. I tried tapping new threads before that but my hole was too buggered up. My cell phone pics are crappy but I got her all back together and drove her for a while, no exhaust leak engine didn't blow up or overheat so I guess it was a good day
08-15-2013, 12:26 AM | #5 |
