Old 08-14-2013, 03:51 PM   #1
68lngbed350
Rear end interchangeability
I have a corporate 4.57 rear in my 1968 3/4 ton 8 lug pickup with rear coil suspension. I found a 1959 chevy panel truck with a 6 lug coil corporate rear end with 4.11 gearing. My question is if I can simply swap the carrier (pumpkin) of the 6 lug 4.11 rear directly into my 4.57 8 lug rear? So my truck can have better freeway manners.
1968 C20 Stepside 350 sm465 4.57 - Summer Cruiser/Hauler
1980 El Camino- lil brothers dd. lt1 3.90
1970 Camaro-468 bbc t56 4.11 MONSTER! younger brothers project
68lngbed350 is offline   Reply With Quote
Old 08-14-2013, 06:02 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Rear end interchangeability
The first thing I would ask is if the axle spline count is the same. You will not be able to swap the 1959 axles because the housings are more than likely different widths.
Will the 59 carrier bolt into the 68 housing? If it does, then your only problem maybe axle length and spline count.
TBONE1964 is offline   Reply With Quote
