Old 08-15-2013, 05:28 PM   #1
his15153
Headlights keep blowing fuses
So my headlights seem to keep blowing the fuse. After the fuse blows, I have to switch to the high beams, which don't seem to blow any fuses. I changed the headlight switch, thinking that it might be the cause. I have driven the truck once at night since then, and the headlights worked for about 10-15 minutes, before it blew the fuse. Now, when I put the high beams on, all the lights flicker on and off. If I turn the lights off for a few seconds, they will stay on for a minute and flicker again.
his15153 is offline   Reply With Quote
Old 08-15-2013, 05:57 PM   #2
cdowns
cdowns's Avatar
Re: Headlights keep blowing fuses
you have poor grounds causing all your problems
Old 08-17-2013, 03:18 PM   #3
his15153
The wiring looks fine. I don't see anything that looks out of the ordinary in terms of the wiring. Except for one wire. There is one black wire coming into the cab that is in the bundle with the other headlight wires that seems to have had the shielding melted off of a bit of it. Also, it is not hooked to anything. I tried grounding it, but nothing happened. The light still flicker. I have also noticed that you get a bit of a flicker in the gauges as well when it happens.
Old 08-17-2013, 03:25 PM   #4
cdowns
cdowns's Avatar
giving those wires a stern look and pondering the state of the universe accomplishes nothing
plug back of light bulb trace wires take wires apart clean wire contacts to bright metal to metal contact // that is the old school way of gettin lights ta work
Old 08-17-2013, 04:03 PM   #5
SS Tim
SS Tim's Avatar
Since the truck does not have a headlight fuse it sounds like there are issues. The factory headlamp switch has a built in circuit breaker for protection. First thing I would suggest is looking at a manual and running the wires down.
The factory manuals can be downloaded here with some wiring diagrams in the service manual unde body electrical.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 08-17-2013, 06:26 PM   #6
Wrenchbender Ret
These trucks don't come with fuses on the headlights. What amp fuse are you putting in? Put a voltmeter on the battery & see what the regulater is doing. If the voltage jumps around that is what your flickering is caused from.
Wrenchbender Ret is offline   Reply With Quote
Old 08-18-2013, 12:25 AM   #7
heyjoe
Another thing to check is the floor mounted hi-beam switch and its connector.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
Old 08-18-2013, 01:20 AM   #8
pritch
pritch's Avatar
Which fuse is blowing?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-18-2013, 02:29 PM   #9
his15153
The fuse that keeps blowing is the fuse on the front side of the fuse block (on the other side of where the wires attach). I've uploaded a picture of the fuse block, it is the missing fuse that is the one that keeps blowing.
Also, I have pictured the one wire that has the shielding melted off.
Also, when I put the old headlight switch back in, the lights stopped flickering. The fuse still blows though. So I don't know if the flickering with the new switch is because it was defective, or there is another problem.
Old 08-18-2013, 03:09 PM   #10
heyjoe
What the heck kind of truck is this? What year they started putting in that type of fuses?
Old 08-18-2013, 03:24 PM   #11
SS Tim
SS Tim's Avatar
If that is a 67-72 truck then it has some sort of replacement wire harness/fuseblock. With melted wiring and apparent shorts I'm going to have to tell you to get help locally if you are not familiar with auto electrical systems. To be on the safe side I would also suggest pulling the negative battery cable too. This is not going to get better by itself.
Old 08-18-2013, 03:30 PM   #12
heyjoe
x2
That's what I was kinda thinking.
Old 08-18-2013, 04:22 PM   #13
Special-Ed
Special-Ed's Avatar
its time to hire a pro!
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 08-18-2013, 04:56 PM   #14
Bigdav160
Bigdav160's Avatar
It would help to have a little better picture of how the fuse block is wired in. The color wire that connects to the fuse would help determine what part of the circuit your problem is in.
Fuses blow because of the lack of designed resistance in the circuit. The source of resistance in your case is the headlamp bulbs. What kind of headlamps does your truck have?
If it was my truck and I didn't have any electrical tools I'd start with disconnecting the head lamp bulbs. Turn on the lights, flicker the dimmer switch, grab the harness with my hands and move them around. If the fuse still blows disconnect the dimmer switch and do the same thing. the problem is a chafe in the harness to metal.
If the fuse doesn't blow with the headlamp switch "on" then there is something wrong with your headlamp bulbs. Plug them in one-at-a time and do the above testing.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
