Old 08-15-2013, 05:34 PM   #1
klutz51
front air bags on solid axle
I am thinking of fabricating air bags on my 51 using my straight axle removing leafs in the springs and running bags between the frame and upper spring plates where the bumpers are. has anyone seen or attempted this? I saw how ride tech has the rear air over leafs and thought about doing it in the front.
klutz51 is offline   Reply With Quote
Old 08-15-2013, 06:37 PM   #2
lowrodderchev
lowrodderchev's Avatar
Re: front air bags on solid axle
yes ive seen it a friend of mine had a 50 chevy truck he did it on said he liked it dont remember hwta the set up look like.
lowrodderchev is offline   Reply With Quote
Old 08-16-2013, 08:56 AM   #3
klutz51
cool thanks I was hoping that it has been done and I am not wasting my time.
Old 08-16-2013, 09:02 AM   #4
Rude Dude
Rude Dude's Avatar
The only issue I could see is steering binding from box to steering arm. Bags on in place of coils not affected to much because A Arm design, but straight axle the bum steer is really affected cause your limited on movement if it is to much of an angle will bind on you.
Rude Dude is offline   Reply With Quote
Old 08-16-2013, 10:34 AM   #5
lowrodderchev
Look at the lowrider mag website alot guys did it on there 49-54 chevys
Old 08-16-2013, 11:08 AM   #6
NEWFISHER
NEWFISHER's Avatar
My Burb still has the upper plates where they had run bags above and the core axle I sent Sid at droppedaxles.com had a bracket for a pan hard bar welded to it and the u bolt brackets had plates welded to them. I don't have any pic's of the old stuff. I gutted it to run stock leafs and a dropped axle. The upper plates come outboard of the frame just above the axle.
NEWFISHER is offline   Reply With Quote
Old 08-16-2013, 03:11 PM   #7
klutz51
the truck has the cpp saganaw gear mounted to the front of the frame when I bought it, so I don't think I will have any issues with the steering being in the way
