Old 08-16-2013, 12:38 AM   #1
wesmigletz
wesmigletz's Avatar
Lost Electrical Power to Truck - what do I check
When I started my 67 truck tonight it fired right-up, then died. I have no headlights or IG. The battery has 12.7 volts and there is a junction block near the battery. I have 12.7 volts on it as well.
Is there a fusible link or a hot connection I can check?
Thanks in advance,
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 08-16-2013, 10:43 AM   #2
wesmigletz
wesmigletz's Avatar
Re: Lost Electrical Power to Truck - what do I check
Where does the main power feed go? I'm just trying to get an idea where I can check.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-16-2013, 10:46 AM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
First thing, take the terminals off and clean them. Best place to start. Then make sure your ground cable has a good clean connection to the chassis and the body. From there trace the positive cable down to the starter and make sure power is there. There should be a fusible link or two on the solenoid at the starter. Check those and let us know what you find.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-16-2013, 12:32 PM   #4
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Super is correct.
Start there and work your way slowly following the path of the electrical wires. Pay attention to each wire and its condition as you trace it to a termination point.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 08-16-2013, 01:04 PM   #5
BLACKLINE61
BLACKLINE61's Avatar
Exact same scenario happened to me last week and Super is 100% correct on checking the battery terminals first, the neg looked clean but wasn't making contact other than a few pinpoints
BLACKLINE61 is offline   Reply With Quote
Old 08-16-2013, 01:41 PM   #6
wesmigletz
wesmigletz's Avatar
Thanks for the feedback. Both cables are pretty ratty. I'll replace them and trace the wires to the starter and see how they look.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-16-2013, 08:37 PM   #7
wesmigletz
wesmigletz's Avatar
I got the engine cranking over and firing. I do not have headlights, turn signals or horn. I have 12.7 volts at the regulator on the D side core support.
Fuses looked good when I checked them.
Any ideas?
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-17-2013, 05:31 PM   #8
wesmigletz
wesmigletz's Avatar
I traced a hot wire into the cab. It had 12.6 volts at the horn relay. I also have 12.6 volts at a red wire in the head light switch.
So, I replaced the horn relay and headlight switch with parts from my other truck, but still do not have head lights, turn signals, or wipers or tail lights.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-17-2013, 08:39 PM   #9
wesmigletz
wesmigletz's Avatar
Fixed it. Re-checked and cleaned the grounds. There was a lot of corrosion. Everything works now.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-18-2013, 05:18 AM   #10
C20-67_N_MO
Thumbs up Re: Lost Electrical Power to Truck - what do I check
Congrats!
Old 08-18-2013, 05:18 PM   #11
wesmigletz
wesmigletz's Avatar
Originally Posted by C20-67_N_MO View Post
Congrats!
I was over thinking it. It really was the basics.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
