08-17-2013, 11:00 AM | #1 |
Horn question for 1977 Stepside
My horn seems to work about 80% of the time. I believe it is a ground
problem on the horn assembly. My horn is located between the radiator and grill on the passenger side. My question may possibly be applied to a great many other Chevy PickUps. Here goes: What is the most simple and painless way to get to the horn to work on it. There is very little room from the bottom of the truck to stick your hand in there. I have jiggled the wire but would like to get in there to clean the contacts better and clean the ground connection. All help is welcomed and thanks in advance. Larry P.S. Everything checks out OK on the Steering Horn Buttom |
08-17-2013, 11:43 PM | #2 |
Re: Horn question for 1977 Stepside
Unscrew the grill and remove it to get to the horn. Clean the contacts really well and you should be good.
08-19-2013, 06:47 PM | #3 |
Re: Horn question for 1977 Stepside (ShortBed)
Ok; here is my update: Got the horn working well by cleaning the ground
and the wire (contact) on the horn. Did not have to take the grill out just the passenger side Bezel. Also this perticular truck has only one horn. Larry |
