08-18-2013, 03:35 PM | #1 |
73+ Crossmember LCA mounts
I have a 73-87 xmember that I want to swap, unfortunately at the time I was shopping for one there were little to non available in my area. The one I bought had some torch work done to get the lower control arms loose in hurry, Im guessing someone wanted the springs anyway the plates on the top side of the mount were bugered up with slag. I go one cleaned up pretty good after much time with a hammer and chisel. Itleast one of the others looks like the plate itself may have been hit with the torch(plate only not xmember). Is it safe to just drill out the rivet to remove the lower mount and make a new plate for the top than replace the rivet with a bolt?
08-18-2013, 06:52 PM | #2 |
hillbilly
Re: 73+ Crossmember LCA mounts
got any pics?
-1962 C-10 |
08-18-2013, 08:08 PM | #3 |
08-18-2013, 09:11 PM | #4 |
hillbilly
looks pretty bad.that is the side that the nuts go on.
-1962 C-10 |
08-18-2013, 09:46 PM | #5 |
couldent I drill out the rivet and chisel off the plate and than make the same plate out of flat bar and bolt it on?
08-19-2013, 02:09 AM | #6 |
60-66 Nut
Yes you can replace that reinforcement plate and replace the rivet with a bolt. However you will have to do it in such a way that the bolt is long enough to locate the LCA shaft the same as the rivet does. I would use a grade 8 bolt.
08-19-2013, 07:40 AM | #7 |
Without going into too much detail or why, Some guys (& me) take that rivet out and replace with an Allen bolt as it locates the lower control arm shaft. The plate should be easily removable at that point and any irregularities could be filled with a welder and ground down.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-19-2013, 09:14 AM | #8 | |
Right now, you at the perfect point of doing the caster mod that I did in my '64 build thread. You will need to find a machine shop that can duplicate the spot-face holes in your lower crossshaft. It's a very easy mod that will move the lower control arm forward 3/4" and help you gain some much-needed caster.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-15-2013, 05:11 PM | #9 | |
09-16-2013, 11:35 AM | #10 |
If you're talking about the removal of the LCA saddle rivets, I used my small torch set and heated the rivet head cherry red and then hit the trigger and blew the head off. While it was still hot, I used an air chisel with a pointed tip to drive the stem out. I've done this quite a bit in the past, and got pretty good at doing it without damaging any adjacent metal. Another method is to use an angle grinder and a cut off wheel and grind the head flush to the crossmember and drive out the stem with an air chisel. Another method would be to drill out the center of the rivet by starting with a small bit and stepping it up until you get to the outer diameter of the rivet stem.
It's knuckle-busting work, but the results are worth it.
09-16-2013, 12:36 PM | #11 |
Here's a thought- if you've got all the control arms already off, why not just bolt them to your original crossmember?.
Seems like a lot of work being done on a part that doesn't have to be changed. The main reason a lot of guys switch out the whole thing is so they do not have to disassemble it piece by piece. |
09-16-2013, 06:50 PM | #12 | |
09-16-2013, 06:54 PM | #13 |
No way of knowing what you were working on, just mentioned the crossmember swap.
So are you converting a C20 to a C10? Or Staying C20- to C20? What year are you working on? Any info you provide can help us who are trying to help you. |
09-16-2013, 07:06 PM | #14 |
Ya I should have mentioned that I dident mean to sound like a smart ass. But anyway its a 66 C20 that im switching to c10 5 lug. Ive got a 73+ front and a 68ish 14 bolt rear that Im either going to get redrilled or buy new axles for
09-17-2013, 12:23 AM | #15 |
60-66 Nut
The 14 bolt didn't come out until '73, and only in the 10.5" full floating version. The semi floating 9.5" 14 bolt didn't come out until '79. Either one will be a bit wider that a typical '63 to early '70 C10 12 bolt. I would suggest just finding a '63-'70 12 bolt, and just buying the conversion axles if needed. The '71-'82 12 bolt will also work, but they are 1.5" wider than the early 12 bolts. Plus the '73 + will require cutting and welding to be able to bolt the under your truck.
09-17-2013, 04:19 PM | #16 | |
thanks |
08-21-2014, 07:40 PM | #17 |
Does anyone have up close pics of where they cut out the rivet and replaced it with an allen head bolt?
