![]() Join Date: Sep 2011
400 turbo column shift linkage
Come off my 69 burb $60
------------ Scott |
Re: 400 turbo column shift linkage
Any pics?? Thanks
Couldn't add pics but I can text or email them.
Always on the hunt...
![]() Join Date: Sep 2006
Just an FYI, for the V-8 there were two separate TH/400 cloumn shift linkage setups. One is the standard small block with Th/350 & 400 setup with the second setup being for the big block with Th/400. Mel
I might be wrong but those look to be different due to the different frame rail size between 1/2 ton and 3/4 ton. I am often wrong but the lower one looks like it would not fit in a 1/2 ton frame rail. Both of my 1/2 tons have the upper style and both were factory small blocks. HMMM as I scratch my head.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
The one I have for sale is the small block style like at the bottom of the picture.
Bump
![]() Join Date: Jun 2005
All TH400 equipped trucks were not necessarily big block trucks. But all automatic equipped big block trucks used TH400 trans AFAIK.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
The question I have is, can I use the TH350 style linkage with a big block? If not, what will be the hang up?
Can I ask I have heard that the shift linkages on the 67-72 trucks will work on a 60-66 truck but I'm not sure.
I'm going from a powerglide in my 65 c10 to a th350 an wondering if this would work? |
