6 inch drop
Tried to do a search but my computer started tripping. Do I need to do a c-notch on the rear of my 70 c-10 if I do a 6 inch drop? Or can I get away without it? Thanks for any help.
Re: 6 inch drop
If memory serves correctly, that is the critical point to which some guys will say yes, but others will say no. If you're not towing or using the bed for any kind of load, then you should be fine. Keep in mind that every truck is different. You might be hitting the bump stops a lot if your roads are as bad as Houston roads.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
Moderator
![]() Join Date: May 2007
Re: 6 inch drop
You might, you might not. Install the springs and decide from there
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 6 inch drop
I agree 100%.
Re: 6 inch drop
I don't think Dallas roads are much better. But I don't haul anything except my kids now and then. I'll just put them in and take it from there.
Knomad, are you going to be at the Houston battle drag in Oct? I'll be Maine the journey out there. Hope my truck is done. Posted via Mobile Device |
Re: 6 inch drop
I don't know. Honestly I hadn't heard of it before now. It would be worth checking out though. I'll see if I can make it, but not sure at this point.
Re: 6 inch drop
When I did my 6 inch drop I did the notch but I also have a sway bar that mounts to the top of the axle. I had do. I also found my new springs are soft so you will need to check that. Seems like some are softer than others requiring more clearance.
I would say yes to be safe but try it...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
///Relaxed Atmosphere
Re: 6 inch drop
No notch needed then just trim your rear bump stops, you should be ok.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
Re: 6 inch drop
I would do it or there will be some thuds in ur future.
