Fabricate till you "puke"
5.3 head gasket guestion?
I dug up the numbers in Oreillys site, for the head set (2000 GMC 5.3). There is a number listed for 99-01 (HS9292PT).... also a listing for 02-08 (HS26191PT). Both are Felpro numbers, but it appears that the 02 up has the MLS gaskets ? My question, is will the later set work with my 2000 engine, or are there differences in some of the other gaskets in the set? Thanks for any thoughts on this.... Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
meowMEOWmeowMEOW
Re: 5.3 head gasket guestion?
Old style heads have this little notch and use a graphite gasket, not the MLS gasket that the newer style uses. The metal MLS gasket will leak on that head.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Many thanks for the pic! just to clearify...is it the old style on the bottom in the pic? Thanks again...longhorn
meowMEOWmeowMEOW
yep
this site is amazing.... lots of others gain from this too.. so .. thank you
Thanks again! I just got the heads back from the shop & no notch....looks like I am going for the MLS set
