08-25-2013, 01:37 AM | #1 |
Are the antennas any good???
I just installed my Alpine stereo in my 73 and hooked up the antenna wire I found under the dash. The reception for the radio was not great and would cut in and out. I stopped for gas and when I restarted the truck the tuner was just static. The antenna was still plugged in and everything else on the stereo worked.....CD, Bluetooth, etc.
Since I don't see an external antenna I can only assume it is in the front windshield. Anything else I need to check? Posted via Mobile Device |
08-26-2013, 01:46 AM | #2 |
Re: Are the antennas any good???
Make sure the antenna is still connected to the button on the bottom of the windshield. It could have came loose.
08-27-2013, 05:05 PM | #3 |
I'll check that tonight
1973 Chevy K20 |
08-26-2013, 01:34 PM | #4 |
probably not connected to an antenna
if you don't have an antenna hole, like my shaved truk i bought a $10 autozone antenna and mounted my it under the truck works fine
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
08-26-2013, 01:47 PM | #5 |
08-27-2013, 02:14 PM | #6 |
for $10
nope just the cheapest antenna i could buy in your location it will only pick up a hundred or two stations
08-30-2013, 09:42 PM | #7 |
So it turns out that I had the wrong antenna plugged in. The PO at some point must have had an aftermarket antenna. I grabbed the wire under the dash and plugged it in without tracing it back. It was cut and ran to nothing.
I found the one that runs to the windshield and now it works great.
1973 Chevy K20 |
