700r4 ?
What TV Cable mounting bracket are you guys using & What was it off of? If any one has a pick it would be helpful . also what is the best place to pull power from , does it need to be fused & what size? thanks
huh ???
I got mine from Auto Zone. Its made by Spectre and it was around $20. Nice thing about it, it's adjustable...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Thanks chuck I'll check them out , where did you tie the hot wire in at ?
Progress = 0%
Spend a little extra money and get one of these systems....... works great!
Bowtie Overdrives TV cable
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
14.1 @ 96MPH
I just bought mine from the dealer, both the bracket and cable for an '80s pickup with a carbbed small block.
Power can be from anywhere you get 12V while it's running. Doesn't need to be fused IIRC. Might wanna check out the 700R4 FAQ while you're at it. ![]()
Project1970 - LS1 Swap Complete! ![]() |
![]() Join Date: Jul 2000
P/N 25515598 Throttle valve cable @ $20.00 and Bracket P/N 22504927 @ $17.00 (GM) . Bracket has oppenings for accelerator cable and for the T.V. cable and bolts to back two bolts on Quadrajet.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
thanks guys , & Don for the part # 's that helps.
14.1 @ 96MPH
Don: I'll throw those P/N's in the FAQ, thanks!
Stupid question, but what is a tv cable for? what does tv stand for? not television i dont think!!!
Thanx Dale ![]() ![]() ![]() ![]() ![]()
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
Progress = 0%
TV = Throttle Valve. The TV cable "tells" the trans when to shift.
97' Tahoe 2dr/2wd
don smith,
do you have any pictures of your set up? |
I've got a Lokar set up.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
On my '72 I used the brown/white wire for the TCS solenoid (solenoid removed by PO). Not sure if your -69 has the same circuit or not. The wire had a disconnect ~12" from the main firewall connector and was routed in the "gutter." The circuit shares a 4 amp fuse with the radio (stock) and has been working fine for several months. The solenoid doesn't pull that much current, but I would recommend protecting the wire with a fuse of some sort since it is a 12 V source.
Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
I have pictures of my setup. Will attempt to scan and post later in the week.
