Old 08-27-2013, 10:27 PM   #1
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
WTB Long Water Pump Power Steering Bracket
Looking for a Power Steering Bracket for a '67 swb 2wd with a 350 with a Long Water Pump.
Thank you,
Bob
Sandemonium is offline   Reply With Quote
Old 08-27-2013, 10:31 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: WTB Long Water Pump Power Steering Bracket
Bob,... all 67-72 SBC equipped trucks came with a "short" water pump.
You might have better luck looking in the 73-87 classifieds area.
They all came with long water pumps.
Keith
Convert to disc brakes.
Old 08-27-2013, 10:36 PM   #3
WETOWM
Do you have all the correct pulleys & the p/s pump ? I probley have what you need for long water pump
WETOWM is offline   Reply With Quote
Old 08-27-2013, 10:49 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Bob,
If you have the "short" style p/s pump brackets they will work with a long water pump set up. I am attaching a photo of my truck which is set up that way. I am going to change it to a short water pump in the future but the p/s pump brackets are the same.
Actually, this is not a "long" vs "short" water pump problem, it is a pre 72 / post 73 problem. GM did not start the long water pump on pick ups until 73. The 73 and up engines had all stamped steel brackets for the p/s as where the 72 and under had one stamped steel and one cast bracket.
I hope this helps clear up some issues.
TBONE1964 is offline   Reply With Quote
Old 08-27-2013, 10:54 PM   #5
WETOWM
that is correct but the cars started the long water pump in 1969 model year ya its not correct but if you are using the long waterpump you will need that style of brackets and pulleys
Old 08-27-2013, 11:19 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Good to know. Based off the photo of my truck, is the p/s brackets correct for a passenger car with a long water pump? I am trying to get educated on this too. I don't recall ever seeing a long water pump engine with this style of p/s brackets.
Not trying to hijack here just want to make sure Bob gets what he needs.
