Motor is painted and ready
My 305 is now diguised to look like a 283 and ready for install...
![]() Join Date: Oct 2007
Re: Motor is painted and ready
Very nice! I'm concerned that the oil filler tube and breather in your intake manifold may not be sufficient for venting the crankcase. It may blow oil all over your motor.
Like you, I have been thinking about disguising a later model engine into my truck and using the "Chevrolet" scripted valve covers. Since you obviously can't use breathers or PCV with those valve covers, I've wondered if there is a way to drill a hole in the rear of the engine block, above the bellhousing flange, and install some sort of road draft tube like the older, original engines used. But your engine looks great. Very cool idea. And it may work just fine with just the one vent. |
What color paint did you use, if you don't mind me asking?
![]() Join Date: Apr 2012
I'm in the exact same boat. Mine is a 283 with 305 heads, I found I was missing the vent canister that goes in the valley under the intake. Of course I found this out after I set the intake. |
New Ford Gray Ceramic Paint from PepBoys...
Now for the Breather. Jegs has a bulkhead Rocker Cover breather with Baffel JEGS Performance Products 50128 Valve Cover Breather Baffle. Drill a hole in the back of a valve cover, attach an angled pcv and run a hose to the intake. I'll post pics after the motors in. |
That PCV fitting is neat. Going to have to get me one of those.
In and out... Several odds and ends to finish but getting close
those motors look sweet
![]() '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
Motors gotta come back out... Tech tip for any one else replacing and engine with a clutch.... Make sure the holes have been drilled and tapped for the clutch bell crank block ball. Mine has to un drilled boss spots.... O well live and learn.
Posted via Mobile Device |
Where it needs to be via a bracket with ball i found
Why don't you just make a flat bracket that bolts to the bell and the motor mount with the ball on it. Better than possibly ventillating your block down in that critical area by the filter.
Kinda like this. http://www.digitalcorvettes.com/foru...ad.php?t=20492 Last edited by geezer#99; 09-06-2013 at 06:34 PM. |
Geezer many thanks. It was too hot in socal today so i ran parts instead. Saw your post and ordered just what i needed. So glad i won't be yanking and risking scratching the resto work....
Motor looks killer let me know how it runs Im building a 64 I got a 350 to go in it and I really love the scripted valve covers with the intake with the breather and maybe some pics of that rocker cover breather installed
Rollin' Old Skool
First off, beautiful engine & truck! As for the valve cover dilemma, here's a similar set of valve covers that Delmo modified. Dino did something similar on his latest bagged blue '66 short/fleet, except the breather/PCV hole is on the back of the cover.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#15 |
![]() Join Date: Aug 2013
#16 |
Very nice work...those engines look great. Here is my work in progress...finished the bypass system for the heads...hopeing to plumb the fuel lines this weekend. I like the breather adapter above for the valve covers...think ill look into them myself.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-19-2013 at 08:56 PM. |
