Old 08-28-2013, 12:59 PM   #1
Redleg87
camshaft combo
Hey.. engine is broke back down.. just put in a new crank/bearings..etc with 40 over pistons.. compression is 9:1 with 202/160 heads 64cc
I have a solid cam here that's .512/.536, and 262/273@ .o50...
Rockers are 1.5's..
Will this cam be ok? Is it going to make decent power?
Also running a 4 speed w/ 4:11 rear
Need more info?
Redleg87 is offline   Reply With Quote
Old 08-28-2013, 01:11 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: camshaft combo
Going in a 350? That's a pretty snotty cam if it's in a small block. You'll need headers, and not to mention an intake and carb setup that will match that cam.
What heads specifically, and who is the maker of the cam?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-28-2013, 01:28 PM   #3
Redleg87
Re: camshaft combo
World aluminum... have a good intake.. carb and long tubes.
Old 08-28-2013, 01:57 PM   #4
mmiddle
mmiddle's Avatar
Re: camshaft combo
Wow, That's an aweful lumpy cam for a truck.
You can run it, but wow it would be better at home in a stout bracket car.
If you do, make sure you have the proper springs installed and screw-in studs. Run only 93+ octane and a matching carb/intake and distributor. The stock GM HEI is only good to about 6k, this cam will go 7K easy. You will need a MSD 6AL and matching coil for your dizzy.
The gears and tranny are great for this cam.
I do have one question... You stated 9:1 CR with 64cc heads.... Are you planning on a blower or turbo? Where did you get those pistons?
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 08-28-2013, 01:34 PM   #5
Redleg87
Re: camshaft combo
I'm not at home or I'd give more specific
Old 08-28-2013, 02:04 PM   #6
slow-1
slow-1's Avatar
Re: camshaft combo
I am no expert, but I think you will need more compression also.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-28-2013, 02:50 PM   #7
Redleg87
Re: camshaft combo
Springs are fine for it..x2 checked with manufacturer.. I am planning on running a turbo 6-10psi.. and didn't want to buy pistons twice (flats to run while saving for turbo) so I got said pistons. Manley I believe.. small dish 4 valve relief from a local shop. (Good guy)
Carb intake exhaust are correct for it..
Also.. I do have screw in studs.. I have always loved turbos.. you think I'm on a decent path?
Old 08-28-2013, 03:06 PM   #8
steelhorse
steelhorse's Avatar
Re: camshaft combo
If you are definitely planning on going with a turbo then a turbo specific cam would be better. If you are going to run it without a turbo for a while then the compression may be down with that big a cam. Remember valve overlap bleeds off cyl pressure.
steelhorse is offline   Reply With Quote
Old 08-28-2013, 03:26 PM   #9
mmiddle
mmiddle's Avatar
Re: camshaft combo
Ok... I get worried when people post about such a lumpy cam.. I don't how many I have pulled out of engines because some gommer wanted to fast and the parts guy sold him a drag racing cam for a truck. And then the CR you posted was leading me to that conclusion.
Awesome... this thing is going to be a bat out of hell. Just make sure you have strong spark the HEI is good with a 6AL and big coil.
Mark
Jesus is the Way!
Old 08-28-2013, 03:29 PM   #10
mmiddle
mmiddle's Avatar
Re: camshaft combo
It will run fine. May be a little ( alot) dumpy at low RPMs. Gonna get horrible milage.
Mark
Jesus is the Way!
Old 08-28-2013, 03:44 PM   #11
Redleg87
Re: camshaft combo
Haha.. oh no.. I would have went with flat top and a 488/508... just to be peppy... just didn't want to double build this thing.. looking at the long term (4 months) goal... turbo with 5-10lbs.. just to have something different.. I love my truck and bought it with money I made in Iraq.. just want my dream.. not a nightmare
Old 08-28-2013, 03:23 PM   #12
Redleg87
Re: camshaft combo
^ agreed. But it should build good mid range power and be cruise able for the time being correct?
It'll be turbo by January, but I'd like to drive it to school and back(10 miles round) and to some car shows...
Old 08-28-2013, 03:36 PM   #13
Redleg87
Re: camshaft combo
Lol.. I know low end power will be $#it... but I just want er to run for now.. a new can with the turbo won't be a prob.. just don't have it to buy a new one till I get my back pay from the v.a.
What kinda of power you think it'll make? 400?450? As is.
Old 08-28-2013, 03:46 PM   #14
Redleg87
Re: camshaft combo
I have a older 6Al... just need the coil... hei for now. . But it for sure isn't staying n/a.. like I say.. Santa is bringing a turbo kit. love my wife and thank Christ for the blessings.
Old 08-28-2013, 05:04 PM   #15
slow-1
slow-1's Avatar
Re: camshaft combo
Originally Posted by Redleg87 View Post
Santa is bringing a turbo kit. Posted via Mobile Device
That will help considerably with the compression.
Old 08-28-2013, 03:51 PM   #16
GASoline71
GASoline71's Avatar
Re: camshaft combo
All that info about a turbo and the MSD box would have been a lot more help in your opening post.
You need to be careful when picking cams for turbos. If you're too aggressive then the turbo won't be able to work as efficient.
What is a "good intake and carb"?
You're going to have a top end spinning fire breathing monster. Make sure your bottom end is stout, and you have forged pistons as well.
Gary
Old 08-28-2013, 04:06 PM   #17
Redleg87
Re: camshaft combo
Gary
I was on my cell and couldn't write a huge thread. Info was given tho.
C&s holley 850 aerosol and a weiand stealth intake.. I believe that's what they call the intake
Old 08-28-2013, 04:07 PM   #18
Redleg87
Re: camshaft combo
Pistons and rods are forged... crank isn't.but its new.. with all new bearings. Everything on the bottom is new. And hopefully will hold up on this combo.. the only thing I was doubting was running this cam until I turbo this winter. Specs match up for everything to hold up top.. but just didn't know how it would perform
Old 08-28-2013, 04:09 PM   #19
Redleg87
Re: camshaft combo
Also have an edelbrock 750.. but I believe the holley is better imo
Old 08-28-2013, 04:32 PM   #20
GASoline71
GASoline71's Avatar
Re: camshaft combo
Edelbrock carbs make good door stops. Nobody making power with any kind of engine uses and Edelbrock carb. Stick with the Holley... you'll be glad you did.
Gary
Old 08-28-2013, 04:59 PM   #21
Redleg87
Re: camshaft combo
Haha.. yeah.. c&s hooked this one up.. (holley)
The eldecrock is just sitting here
Old 08-28-2013, 06:36 PM   #22
Redleg87
Re: camshaft combo
The dish isn't too bad.. just double checking with the motorheads. That I can run around till then...
Not a "slam a huge cam in it with low comp guy"... if it wasn't safe to run it till Xmas... I wouldn't.. . But since its ok... I probably wouldn't mind busting a gt's ass around town.... got a 03 gt guy with a exhaust running his moith .. think he has a diablo tuner and a "cold air"......
Other than that.. just checking.. I've built it compression. Wise for my turbo.. that's coming... in the winter...
Just anxious to at least drive around till then.. school is just down the road and I haven't had a decent ride since I sold my pro charged camaro...
This is my dream car.. "truck" before my dad left which was when I was just old enough to remember his face... he had a 72 in the driveway and I would sit in it and play...
Ready for reality
Old 08-29-2013, 11:43 AM   #23
mmiddle
mmiddle's Avatar
Re: camshaft combo
The stealth intake is idle to 6k... I think. Your going to need something that will flow clean to 7500 with that cam. The heads and intake need to be port-matched as well to flow right.
The problem we have here is not your plan... you have a good one. But there is a lot that goes in to building an engine like you are. With forced induction, I'm a little leary of a cast crank. There is a lot of extra tortional activity going on at high torque high RPM high boost situations. Your block needs to be 4 bolt mains as well and perferably splayed mains and a windage tray is manatory. you also need to stud the engine to make sure it stays together.
This engine really needs to be bullet proof due to the cam and turbo. Otherwise you will be collecting destroyed parts off the street and placing them in the bed while waiting for a tow home.
Mark
Jesus is the Way!
