08-30-2013, 12:18 AM | #1 |
Intake Ducting
What are people using for intake ducting and air filters in your swaps? Throttle body and both sides of the MAF appear to be different sizes, does that make it a pain? Anything I should stay away from?
2003 cable driven 5.3 in a 49 Chevy pickup is what I'm working with.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-30-2013, 01:02 AM | #2 |
meowMEOWmeowMEOW
Re: Intake Ducting
Buy a generic cold air intake kit for a similar year silverado. It will have the filter, maf adapter and the alum tubing in it for about $69. It comes in two pieces with an elbow and a straight coupler. Out of those pieces you can fit a short air intake for pretty much any swap.
Take a look at the early pages of my engine swap in my build I have it shown from plenty of angles.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-31-2013, 10:23 AM | #3 |
Re: Intake Ducting
I bought my CAI from spectre which makes three models for LS engines in 69-72 trucks. You can see mine in this video, as well as the link to spectre.
https://www.youtube.com/watch?v=qTmL...e_gdata_player http://www.spectreperformance.com/in...adiator-6.html
Check out my build: 1972 LQ4 Swap http://67-72chevytrucks.com/vboard/s...=1#post5427693 |
09-01-2013, 11:26 PM | #4 |
Re: Intake Ducting
I've always wandered if anyone has been oiling the Generic filters like the K&N's??? I've been running my ebay intake for a while now, but never oiled it.
09-02-2013, 12:53 AM | #5 |
meowMEOWmeowMEOW
Re: Intake Ducting
When I got mine, and when I really really wash it out, I'll lightly oil it and let it sit around for a day. You really only want a tiny bit of oil to keep the element from drying out and getting brittle.
Read the box though, many of the new ones are designed not to be oiled, since many people have never oiled a filter at all.
09-03-2013, 10:53 AM | #6 |
Re: Intake Ducting
Along these lines, has anyone just put a cone filter right off of the maf? Seems like there would be more air getting to it then behind the engine bay.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
09-04-2013, 06:48 PM | #7 | |
Re: Intake Ducting
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
09-03-2013, 11:50 AM | #8 |
Re: Intake Ducting
Watching!
09-03-2013, 12:54 PM | #9 |
Re: Intake Ducting
I meant battery tray not engine bay. Got a little distracted.
09-03-2013, 01:55 PM | #10 |
meowMEOWmeowMEOW
Re: Intake Ducting
My battery has been moved to the rear, so the air comes right through the venting onto the filter, which sits right behind the old battery spot.
My filter is right off the MAF, did you mean Filter& Maf right off the TB?
09-03-2013, 02:31 PM | #11 |
Re: Intake Ducting
Yeah sorry. Right off of the maf. I would think the air coming from the fans would be cooler even though it runs through the radiator first. As opposed to air that is more stagnant off to the side. If the battery was relocated that would change things but mine is stock.
09-03-2013, 08:34 PM | #12 |
Re: Intake Ducting
here's mine....K&N 99 and up Silverado, battery in the back, huge cone snorkelling up the cold air through the hole...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
09-03-2013, 10:37 PM | #13 |
Re: Intake Ducting
Thanks guys, keep the ideas coming. I did end up ordering the $69 ebay one, though I'm not fond of the red or the blue.
09-08-2013, 12:22 AM | #14 |
Re: Intake Ducting
Which one did you order from eBay?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
09-08-2013, 02:38 PM | #15 |
Re: Intake Ducting
This one:
http://www.ebay.com/itm/CHEVY-SILVER...afa00f&vxp=mtr It'll be here tomorrow so I can report in on how it looks in person.
09-04-2013, 11:56 AM | #16 |
Re: Intake Ducting
I'm just sticking the filter on the throttle body for my first go-round and running speed density (so no MAF plumbing to worry about). I'm using a Spectre P4 cone filter. Once I get it up and running (still a work in progress right now), I'll see what temperature the air readings are, and if they're higher than I'd like, I'll see about relocating it.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
09-04-2013, 01:17 PM | #17 |
Re: Intake Ducting
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-04-2013, 06:18 PM | #18 | |
Re: Intake Ducting
09-05-2013, 07:59 AM | #19 |
Re: Intake Ducting
I believe the Silicon is shiny and the rubber is well...not shiny. the Silicon will maybe hold up to excessive heat a bit more too.
09-05-2013, 01:45 PM | #20 | |
meowMEOWmeowMEOW
Re: Intake Ducting
Real silicone has a bit of sheen to it when its used for the couplers etc. It won't have the same texture as rubber. That "tacky" feeling that radiator hoses etc have is indicative of rubber.
09-05-2013, 09:57 AM | #21 |
Re: Intake Ducting
I looked into it a bit more and it shouldn't be a problem to run those three right in a row but it was suggested to me that I purchase a Saxon PC honeycomb element to put into the maf to reduce turbulence and erratic readings. I should have the engine running in a week or two so I'll be sure to post my findings here.
09-07-2013, 11:47 PM | #22 | |
Re: Intake Ducting
09-06-2013, 03:34 AM | #23 |
Collector of Projects
Re: Intake Ducting
OK... who has a MAF they can measure... I have a 4" intake and I need a reducer for the MAF... they have a 4" to 3.88" that I think is the right...
http://intakehoses.com/Merchant2/mer...gory_Code=RSS1 |
09-06-2013, 08:11 AM | #24 |
Re: Intake Ducting
I just stuck my spectre silicone 4" coupler right to the maf with no problems. Probably not ideal for race applications but it held fine for me without any major bunching in any particular area.
09-09-2013, 02:44 PM | #25 |
Re: Intake Ducting
That was the one I considered as well. The coupler and filter I bought only totaled $35 so I figured if it didn't work at least I'd only have to buy an elbow and tube
