09-01-2013, 12:01 PM | #1 |
help with V8 radiator shroud
not sure if I have the shroud extensions on right. dose any one have pictures of there's ? also looking for the 2 lower V8 radiator cradles
09-01-2013, 12:04 PM | #2 |
Re: help with V8 radiator shroud
here's the cradles I'm looking for
09-02-2013, 12:27 AM | #3 |
60-66 Nut
Yes those shroud extensions are installed correctly. However you are missing the nut clips that clip on where the square recesses are. Otherwise there will be nothing for the screws to grab a hold of.
Sorry, I can't help you with the lower radiator saddles.
09-04-2013, 02:12 AM | #4 |
Try LMC, on radiator page; see the part#'s for supports/cradles and rubber gaskets/pads below.
HTH, Sam 32-0949 RAD SUPPORT/CRADLE-LOWER 2REQ 32-0948 RADIATOR SUPPORT/PAD 4REQ Last edited by luvbowties; 09-04-2013 at 02:13 AM. Reason: spell |
09-02-2013, 07:10 AM | #5 |
as for the nut clips, mine were missing when I installed the rad in the 64. I used bolts/washers to put the shroud on. Worked fine. After the wreck, I transferred the rad to the 65 replacement truck.
As for the lower mounts, its about as easy to make some as search around for originals. Buy the rubbers for upper and lower to help size em....the v8 mounts and rubbers are a bit wider than the I6 sets. I still have the I6 lowers on my truck and would offer em to ya but they ain't gonna fit for your application. |
09-04-2013, 12:10 PM | #6 |
I picked up the proper nut clips from the specialty drawer at my local Lowes hardware.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
09-04-2013, 08:51 PM | #7 |
Can you post a pic of those clips MisterC or maybe a part number?
