Old 09-01-2013, 03:38 PM   #1
Reyals Bemus
Shim size per 1° caster change?
Does anyone know what thickness shim would affect caster by 1 degree? I'd just like to know how many degrees I'll actually be adding before I go stuffing a handful of shims on the forward studs to increase caster.
Reyals Bemus is offline   Reply With Quote
Old 09-01-2013, 05:26 PM   #2
DURG
DURG's Avatar
Re: Shim size per 1° caster change?
It depends on distance between a-arm shaft bolts and spindle height. Probably 1/8" shim will change around 1/2 degree at the most.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
