09-01-2013, 10:31 PM | #1 |
power brakes question
Hi all I was wondering if anyone had some insight on a conversion from manual brakes to power brakes. I have a 68 k10 with factory manual brakes and I want to convert it to power brakes. I was wondering if there is anything else i will need to get other than the booster and some vacuum hose and fittings like maybe a pushrod extension and mounting adapters. if anyone may know about this that would be great.
09-01-2013, 10:45 PM | #2 |
Active Member
Re: power brakes question
If you can get the parts from a donor truck which will be hard to do these days, you will need everything from the brake pedal forward to the master cylinder (pedal pushrod, bracket, booster and booster to m.c. pushrod). I would use the m.c. you have if it's working good now. Just carefully move it forward to give you clearance to install the booster and booster bracket.
If you go aftermarket, they usually provide everything you need.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
09-01-2013, 11:13 PM | #3 |
yeah, but i was thinking just to get all new stuff, since i can get a reconditioned booster and cylinder from orielly's for $120 bucks so all i need other than that is a mounting bracket new push rod and vacuum hose/fittings?
09-02-2013, 12:03 AM | #4 | |
Posted via Mobile Device |
09-02-2013, 01:31 AM | #5 |
is that all i will need? and how much did the whole setup cost you?
09-02-2013, 03:06 AM | #6 | |
Tags |
adapter, booster, brake, power, vacuum |
