09-06-2013, 12:37 PM | #1 |
a few extra opinions before the hacksaw hits NOS parts...
After checking and rechecking I'm 90% sure the pins on the new door handles have to be shortened to function correctly.
Just like to confirm if anybody happens to know before I get to cutting! Thanks --
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
09-06-2013, 12:52 PM | #2 |
Re: a few extra opinions before the hacksaw hits NOS parts...
do you mean just the pin? can you get a picture with both the new and old facing the same way? I'm thinking that they will work as is, but maybe I'm not sure what you are thinking will have to be trimmed.
09-06-2013, 01:42 PM | #3 |
Basically the plate where the pin starts is the red line. and although it's difficult to see from the pic, when I line them up, the new one would have to be cut at the line(blue arrow) that is formed into the pin, almost as if it was scored for this purpose. cutting it there would make them almost the exact size.
09-06-2013, 01:47 PM | #4 |
Cluster King
Have you tried installing the NOS one on the truck yet? I would not cut it unless you absolutely had to. You will notice that the latch lever does move a lot before it "pops" the door open.
I would try installing it and just be easy. I have never seen one that needed cut especially NOS. |
09-06-2013, 02:13 PM | #5 |
I did install it but it wouldn't fully lock. From what I could tell, the plate that the pin pushes against wasn't able to completely move to where it should be because the pin was stopping it. Almost like it was being pressed in half way all the time.
09-06-2013, 02:16 PM | #6 |
Cluster King
Well in that case, you may have to trim it a little. I would do it in baby steps so you don't take to much off.
09-06-2013, 02:15 PM | #7 |
Going to check factory assembly manual and see if it shows anything.
09-06-2013, 02:21 PM | #8 |
67-72 parts collector,…
I had to cut my handle pin to make it work.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-06-2013 at 02:44 PM. |
09-06-2013, 02:35 PM | #9 |
yea, it's as if that scoring was put there for a reason. I wonder if there was another year that used the full length.
Keith, were yours NOS or repops?
09-06-2013, 02:43 PM | #10 | |
Passenger side only.
09-06-2013, 04:44 PM | #11 |
I think it's made that way for rear doors on sub and panel. I think they need longer tab. I THINK!
Posted via Mobile Device |
09-07-2013, 12:01 AM | #12 |
You have to cut for trucks longer for subs, as Tim said
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
