09-09-2013, 07:58 PM | #1 |
battery not charging
i have a 67 c10 and the battery will not charge. I put a brand new altinator voltage regulator and battery in it plus changr the fuses and the battery still wont charge. And advice would be awesome
Posted via Mobile Device |
09-09-2013, 08:46 PM | #2 |
Re: battery not charging
Make positively sure your wires on the regulator are connected correctly. I had the same problem, on my "69, after taking off the (in this case external) voltage regulator for painting and mis-connected the wires. Everything ran well, but the battery would not charge. If not that, then have the (I know it's new) alternator tested. Mine on my "70 was a new replacement and when the battery went dead, I had it tested and it was no good.
09-09-2013, 10:40 PM | #3 |
I replaced the altinator battery and voltage regultor all at once with brand new parts
09-09-2013, 10:38 PM | #4 |
Msgt USAF Ret
Did you re-ground the voltage regulator to the radiator core support and to the alternator?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-09-2013, 10:44 PM | #5 |
It was never set up like that but i will do that first thing in the morning and let you know thank you
