Old 09-14-2013, 04:52 PM   #1
supercharged
supercharged's Avatar
Help With Grille Removal
I have a 1966 Chevy C10 and I need to remove the grille so that I can straighten a dent and repaint it..
I looked all over the grille and could not see any way to remove it without remove the whole front body.
I can’t believe that is what I have to do to simply remove the grille.
So before a either start ripping parts off or just give up, I thought I would ask those far more experienced than I am .
Is there a simple way to remove the front grille or am I screwed?
Supercharged Scottsman
Scottish by birth, American by law,
Texan by the grace of God.
“To avoid criticism say nothing, do nothing, be nothing.”
― Aristotle
supercharged is offline   Reply With Quote
Old 09-14-2013, 05:25 PM   #2
joedoh
joedoh's Avatar
Re: Help With Grille Removal
unbolts from the back, easy peasy. changed out my 65 grille for a 63 in about 12 minutes flat. you dont even need to take the headlights apart, it all stays together.
Old 09-14-2013, 06:38 PM   #3
Irishbleueyes
3 bolts each side from inside the fender well, 2 at the outside 1 inside lower. They will be hard to see and covered with dirt slung up from the tire, thats why you can't find them! You can see the threads from the front right behind the headlight to the outside, and the lower one just under the grille to the inside of the headlight. Spray em down with liquid wrench, they'll be rusty
Irishbleueyes is offline   Reply With Quote
Old 09-14-2013, 06:55 PM   #4
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
X2... Just slide under the front of your truck near the front wheel and look up at the open space where the back of the headlight would be and you will see them if not caked with dirt. I'm right down 146 from you if you need a hand just shoot me a p.m.. Hope this Helps......
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 09-14-2013, 08:31 PM   #5
jayoldschool
Moderator
Thanks, I need to take out my grille to do the black paint...
jayoldschool is offline   Reply With Quote
