09-14-2013, 07:31 PM | #1 |
wipers, wipers, who's got good wipers
I'm at the point of adding electric wipers to my 3100. I want a kit that is 2 speed and self parking. I know there are kits out there but what would anyone recommend.
09-14-2013, 08:08 PM | #2 |
Re: wipers, wipers, who's got good wipers
No experience with them but I seen Speedway has them. Whenever you get a set up that works good let us know, I'm going to have to get something for my 51. I need what you need, 2 spd, park etc.
09-14-2013, 11:28 PM | #3 |
i have Newport Engineering brand, fit fine & work good (2 speed & self parking)
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
09-15-2013, 04:52 AM | #4 |
Old Heap Driver
Mine came from Classic Parts and works perfectly.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-16-2013, 01:01 PM | #5 |
ad or tf?
either way rainX is your friend
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-16-2013, 08:36 PM | #6 |
I used Rainx for a long time on another vehicle and when a vehicle in front of you throws up muddy water your in trouble. Newport Engineering on my 55
09-16-2013, 11:34 PM | #7 |
1949 ad & rain x on the glass. I need wipers for those misty spring days in Seattle.
09-19-2013, 06:05 AM | #8 |
This is the unit from Classic parts, it is a direct bolt in deal with the switch pre wired. I think it is the same as Newport Engineering. I have used their unit on another build and it worked very good. The only issue on the AD truck is the upper cable for throttle control will no longer work due to space limitations. Hope this helps.
Rob |
09-19-2013, 01:04 PM | #9 |
I found out that Classic Parts sells Newport Engineering units. There is one that has a smaller bracket to clear the choke / throttle cable. Newport also sells an intermittent switch but Classic doesn't have it. The prices are the same so I'm putting the Newport unit on my C'mas wish list.
