Any Blower Motors?
Just curious if there is any blower builds on here. I'm building a 51 AD and going to put my 434 out of my chevelle in it. Later, I'd like to install a 6-71 on it. Right now it's a Motown block, Eagle rotating assy, 10 1/2 to 1, Dart 2.30's, super victor, QF 850, and a Bullet mech roller. Anybody got any pics of their AD trucks, blower or not, please post. Looking at some of your builds makes me miss drag racing that much more.
Your UncleBen
![]() Join Date: Dec 2002
Re: Any Blower Motors?
I am doing a blower motor for my truck. 496 BBC with a Hi-Helix 6-71 roots blower on it. Since the blower is somewhat maxed for this cubic inch motor I went with a higher static compression of 9.0:1 instead of going with the normal 7.5:1 for a blower motor. Since I am building a pump gas build this will make the motor not as "lazy" on the street when it is not under boost.
I had Scott Shafiroff Racing do my rotating assembly for the motor so it is ready to go. Still trying to make the final choices on heads/cam but I have a general thought on what I want. lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
Brodix makes a good head for boost. I'd like to build 1 if I can swing it. I'm going to have to build a mild motor for the chevelle and trans, so the 434 will stay as it is for a while. It runs good the way it is but you know how that is, always want a little more. Plus there is nothing like the sound of a blower motor.
My little 383 with a 671, 8:1 comp, 10 lb boost, crappy pump gas. From 2007 up to the end of July of this year I ran a BDS 8-nozzle efi top hat. IMO, the most expensive mistake I have made.
![]() ![]() Now running dual 600 Holley supercharger carbs and liking it much better. ![]() ![]()
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
Coggedbelt75, what was wrong with the inj setup? I ran mech inj for over 20 yrs on my dragsters and loved it. They all were on alky. I hated going to a carb when I built the chevelle. Tried a Holley 950HP 1st, they suck, and I then went with a 850 Quick Fuel and was really impressed. Had a needle and seat problem, emailed them and 2 days later 2 needle and seats arrived in the mail with gaskets. When I go blower carbs, it'll be QF. I have a HP on a guys chevelle out here now that is giving me fits.
Forgot, real nice truck, keep the pics coming.
Your UncleBen
Im running a 355 sbc, forged crank, forged h beam rods, -10cc dished pistons, World sportsmen II heads 2.02/1.60 with double valve springs all matched. 74cc combustion chamber. Mechanical roller cam with a 541/561 lift, chromoly pushrods, roller lifters. 6-71 Weiand Blower, dual Edelbrock carbs tuned, MSD pro distributor with 6AL box and Blaster 2 coil. Still in tuning phase..
I should have went with my first choice....Hilborn. Andy gives nothing but great customer support.
Your ride is looking good Domer. Are you going to leave the compartment open or eventually cut the hood?
Looks good!
Thanks man.. its been a steep learning curve.. I'm not gonna put a hood on it. Im going to build some covers for the tires.
Posted via Mobile Device |
A friend has a S 10 with a 383, 6-71, pro streeted. Truck runs good but he's been having carb trouble. He runs a single carb and the hi dollar hat deal that sets over top the carb. It has the dummie lines, linkage to butter flies, etc, etc. For the price it cost he could have put 2 quick fuel's 650 blower carbs on it and I think it would perform a lot better. Anyway, some bad ass trucks here, looking good and keep them coming.
![]() Join Date: Jun 2006
vht you would be better off going with an 8-71 instead since your over the 427 mark CI wise. Are you keeping the 10.5:1 compression ratio to run on E85? I agree about Hampton, I used to swing by his shop every so often to see what was new when I lived in Downey. Mooneyham on the other hand was a real grouch and if you weren't a race car guy he didn't want to talk to you. Mert Littlefield was a good guy to deal with too and the worst bunch was and probably still are is BDS.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
I'm still in the build process on the truck so I haven't done nothing yet. If I use the 434, I would drop the comp to 8-1 or so. I'd have to run 93 pump gas. I'll have to see how the money is when the time comes.
#15 |
![]() Join Date: Apr 2005
Ls3/6l80/tvs1900
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#16 |
Domer - Your truck is awesome. Do you know if those front bars coming out of the firewall would be NHRA approved the way you have them installed? I really like how they are close to the motor like that.
#17 |
I doubt they would be.. they are just bolted to the firewall with nutserts. They aren't that strong. When I install the actual cage they will be functional.
#18 | |
I'm building a street/strip truck and I know for sure what cage I'm going to have to have, but with the way your bars are, I wonder if they would be approved if they went through the firewall and welded to the cage. |
#19 |
I honestly have no idea.. I don't know what the rules are.. I'm not building mine for a strip truck.. its just a toy/cruiser..
