Old 09-17-2013, 07:19 PM   #1
68basket
6" rear spring or airbag?
I am trying to get my rear to set correctly. I am running 20" and 22" coys with 2.5" spindles with 2" front coils. Currently in the rear i have 5" coils and 1.5" blocks. WIth the larger wheels in the back it has a little too much rake for me. I am trying to decide weather to put 6" coils in the rear or a schrader air bag setup? any suggestions on who to buy coils or airbags from?
68basket is offline   Reply With Quote
Old 09-18-2013, 08:32 PM   #2
tlmoore2501
Re: 6" rear spring or airbag?
I went with bags with schader valves.Its totally adjustable.I drilled holes though the frame for mounting holes and a hole for the air fitting.So the bag is touching the arm and the frame(short as possible).With the blocks you will need a frame notch.I need the bolt in notch and Im not even using blocks.
tlmoore2501 is offline   Reply With Quote
Old 09-19-2013, 07:38 AM   #3
68basket
Where can I buy a Schrader bag setup?
Old 09-19-2013, 09:35 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Early Classic Enterprises has the perfect bag setup for you.
Tom Vogel is offline   Reply With Quote
