Old 09-18-2013, 07:47 AM   #1
Cartelpaintshop
2x4 or 3x4 inside the frame
Well I got the z fixed on the 68 has any one done this before put a 2x4 inside the frame and weld it and then cut the bottom off after the bottom is cut won't the cab hit the ground before the frame
Cartelpaintshop is offline   Reply With Quote
Old 09-18-2013, 08:33 AM   #2
SCOTI
SCOTI's Avatar
Re: 2x4 or 3x4 inside the frame
Yes it's been done before. On these trucks, the cab will hit the ground so there's not much reason to do it (there's a 3/4" diff between the bottom of the frame & cab).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-18-2013, 01:06 PM   #3
tinydb84
tinydb84's Avatar
For 3/4 of an inch I would just weld in a piece of 3/16'' angle iron to the bottom where you cut the frame off.
If you are going to roll your pinch weld up and lay rocker then go with the 2x4
David
Instagram: myfabguy
Old 09-18-2013, 03:43 PM   #4
Cartelpaintshop
I'm thinking laying it on the rockers
