![]() Join Date: Nov 2007
Spring swap
Hi I have an opportunity to get some 4 inch lift springs from a1977 Blazer and was going to install them in a 1968 K10 half ton along with the axle . Does anyone know if the spring lengths are correct. I have been searching for spring lengths ans swaps and not having too much luck here or on the web. I do not know the manufacture of the lift from the blazer just yet and right now I have had no time to go make measurements. If anyone knows off the top of their head please let me know. I know the axle swap will work on the original springs but i would like to put in the lift at the same time
Re: Spring swap
Kinda a long shot but call http://offroaddesign.com/index.htm they should have the numbers you need on the springs.Or worse case if the rears are as long as a pickups you could run them in the front with a b52 kit from diy4x4.com
Re: Spring swap
Measured my71 1/2 ton rear springs and a 76 3/4 ton I just picked up (wrecked) springs were same length.
Posted via Mobile Device |
