windshield wiper motor problems in 1967 c10
Hello;
I have a 1967 c10 I just started working on. The wipers won't always start when I turn the switch, even with a new switch. If I tug on the wiper they will usually start, and then run ok. When they do run, they seem slow....they also don't "park" when I turn the switch off. I know the cab was stripped and painted, so I may have a ground problem....any other ideas? Does it sound like the wiper motor itself? Here in the Pacific Northwest, wipers are very important....even in the summer! Thanks... ![]() |
![]() Join Date: Jul 2015
Re: windshield wiper motor problems in 1967 c10
Ok, I am bringing this one back due to having to go through my wiper system. I am having the same problems with the wipers working slowly and or barely at all. It just started doing this when we had the recent cold snap and Rain-X had carried me through.
Goin to do some more research. |
#3 | |
The Older Generation
Lube the wiper linkage and transmissions under the cowl vent. It could be a ground problem. The best way to test that is get a piece of wire with alligator clips on each end and ground the motor to the dash. It could also be a problem with the switch not being grounded to the dash good. Take the wiper switch knob off (there is a small set screw on the bottom of the knob) and the screw on bezel off and snug the nut up on the wiper switch. (5/8ths inch socket) Don't get too carried away, the switch housing is pot metal so the threads strip easily. Let us know if that helps.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-27-2017 at 12:17 AM. |
Thanks Doc, I will be doing that tomorrow and report back. This site becomes a documentary of solutions for everyday problems.
