09-26-2013, 11:58 AM | #1 |
Emblem Clips
I'm familiar with the speed nuts that attach to the inside of the panel you are mounting your emblem on, like these:
http://www.summitracing.com/parts/oer-11501047 But what I was removing my CST emblem to get the truck painted, it had a sleeve clip, something like this: http://www.ebay.com/itm/Buick-Chevy-...item20ba368b9d The ebay clips are too small to fit the shafts of my emblems. Does anyone know where I can get a larger set? It would make mounting the fender emblems much easier with a set of these. |
09-26-2013, 01:43 PM | #2 |
Re: Emblem Clips
What size is the pin on the emblem and hole in your fender, i have some retainers laying around
09-26-2013, 02:02 PM | #3 | |
Re: Emblem Clips
Thanks! |
09-27-2013, 12:08 PM | #4 |
Re: Emblem Clips
Studs on the custom emblem measure 1/8" (.125); and these fastners seem to fit them. Outside OD measure 3/16". I see what you mean by not using the nuts, hard access. Usually this type of fastner, the stud would not have any threads, like our emblems do, but you could file them down
LMK, if these will help you out, they were used on old english sports cars, so i would have to dig deeper if you need more....the only thing i would worry about is scratching your new paint with the push in fastner. If you use the OEM fastner you can use a small o ring in the nut, and then it wont scratch your paint as you tighten it down. Thats were the rust would start, with bare metal 20130927_115847 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-27-2013 at 12:18 PM. |
09-27-2013, 01:34 PM | #5 |
Re: Emblem Clips
I ended up buying some on Ebay that I hope will work. I'll give them a try when they get here, if they don't work I might take up up on your generous offer. Thanks!
09-27-2013, 02:01 PM | #6 |
Re: Emblem Clips
What was the name of the fastner, barrel nuts?
09-28-2013, 12:09 AM | #7 |
Re: Emblem Clips
You can find those in most help section at the auto parts store
