Old 09-27-2013, 07:12 PM   #1
Aarons72
Aarons72's Avatar
What should I do to make my rearend ride better?
71 GMC burb...lowered a lot...rear end has cut coils and relocated shocks...rides like a trampoline. up and down...side to side. What options do I have that will not break the bank? I have never done much of anything rear suspension wise...
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 09-27-2013, 09:56 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: What should I do to make my rearend ride better?
Squats, sorry couldn't help myself.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-28-2013, 11:46 AM   #3
Aarons72
Aarons72's Avatar
I knew that was coming with a thread like this ha ha
Aaron Anderson
*1962 Nova
Old 09-27-2013, 10:00 PM   #4
hopped up
hopped up's Avatar
Swapping out those coils would prob make the biggest difference. Prob cut too many coils. And new shocks
hopped up is offline   Reply With Quote
Old 09-27-2013, 10:02 PM   #5
5150
C10 Club Tennessee
5150's Avatar
Drop springs typically run around $100-$125 for a pair.
Bryan
www.gmtruckshow.com
Old 09-28-2013, 11:57 AM   #6
Aarons72
Aarons72's Avatar
For the height of my burb now any recommendations for what size drop spring in the back? Also anyone have a shock they really like?
I was thinking about the whole panhard bar?? would that help?
Aaron Anderson
*1962 Nova
Old 09-28-2013, 01:36 PM   #7
CG
BlahBlahBlah
I was always under the impression rear coils shouldn't be cut because their shape and how they mount. I know you can get four inch drop rear coils especially for burbs and panels. I have four inch drop coils and two inch blocks for my panel. I also have shock relocaters. I'm going to have to come up with something different for the shocks though because the shock relocater kit hangs a little below the scrub line ... cant have that.
Old 09-28-2013, 01:38 PM   #8
tlcrz1972
tlcrz1972's Avatar
Now does this side to side explaination, does that infer that the truck shifts side to side horizontally or just rocks (yaws) about a centerline movement.
If it;s the first it sounds like your pannard bar is worn out or missing.
If it rocks (yaws) then you need better springs and of course better shocks, I'll suggest KYB's a little more expensive but worth it. I'm running them on mine and three of the four are the ones I put on it in '88-'89 (150,000 plus miles) The one that went bad was warranted under their lifetime warrantee.
Again worth it.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 09-29-2013, 07:12 PM   #9
Aarons72
Aarons72's Avatar
Ya more of a rocking from than actual side to side. I will look into lowering coils...I just don't want to go to all the work and have them make me ride higher than I am right now...up is never a good direction for me. And Im running kyb shocks but I think they are the cheaper ones
Aaron Anderson
*1962 Nova
Old 09-29-2013, 07:18 PM   #10
5150
C10 Club Tennessee
5150's Avatar
Aaron, is your burb C-notched? If so then get a 6 inch spring. If not then you're going to have to get a 4, you "might" be able to get away with a 5.
Bryan
www.gmtruckshow.com
Old 10-01-2013, 03:11 PM   #11
Aarons72
Aarons72's Avatar
Yes its notched. Are the truck springs and burb springs springs seated the same?
Aaron Anderson
*1962 Nova
Old 09-29-2013, 09:45 PM   #12
CG
BlahBlahBlah
Mine is notched. The only problem with 6 inch springs is as far as I know they only make them for trucks. They are not nearly as stout. I don't have a picture anymore on this computer but I'm sure Ive posted them before ... a shot of a burb drop spring next to a truck drop spring. There is really a big difference.
Old 10-01-2013, 10:35 PM   #13
CG
BlahBlahBlah
Yes
