Flywheel Install
I took the flywheel off the old 250, and am about to bolt it to a brand new 350. Do I align the dowel holes up for proper orientation?
Re: Flywheel Install
This won't help you any but since you have had several people look and nobody answer, are you sure that the 250 flywheel is the same as the one for a 350? I personally have never tried to change one so I would not know about the change over.
Active Member
![]() Join Date: Jul 2007
I know it will fit on the older 350's -I put my old 250 flywheel on my 75 350. I'm not familiar with the newer engines so do don't know.
Anyway, yes, you just align the dowel hole on crank with the flywheel hole.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Active Member
Forgot to mention... some flywheels were drilled for the heavy duty cluch/pressure plate (like mine) and some were drilled for both.
I lined up the extra hole, seemed like a no brainer.
They interchange as long as it's not the one piece rear main 5.7l.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
