Question on steering column
On a steering column, there is a plastic "sleeve" that the cable that operates the gear selector/indictor attaches to. This sleeve attaches to the part of the column that the shifter is mounted to (metal sleeve?), rotating with the shifter when you move it from gear to gear. It is sttached by sliding tabs on the plastic sleeve into the metal sleeve.
Can the plastic sleeve be replaced with out completely dismantling the steering column? In my '91 crew, the gear selector/indicator was off a few gears. I had the bezel off and tried to pull the plastic sleeve out and rotate it so the cable would pull the indicator to match the PRND321, but noticed that there are only two tabs, on one side of the sleeve. It looks like there should be two more across from these two but are gone. I can get the sleeve to stay in place with the two tabs, but it can only be mounted clocked off a few degrees so the cable has slack and doesn't start to move until I am physicly in Drive. I am in D, but it is indicating P, in 3 = R, 2 = N, 1 = D. Hope that makes sense...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Re: Question on steering column
I am familiar with the set up but not sure what you are saying...
Are you saying you want to remove the plastic sleeve on the column and re-index it? That shouldn't be necessary: the "cable" pull attaches to the sleeve via a small metal clip. You should be able to remove the clip and replace it onto the sleeve where ever it needs to be to properly pull the cable into the PRND21 positions. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jun 2009
I would like to add, that it is necessary to completely disassemble the column to replace that piece. The only way you don't have to is if you have a manual transmission truck. Then the column still has to be removed from the truck. Like Keith said you should be able just to move the cable. It is possible on side of the cable is broke or it has stretched. In this case you will just need to replace the cable which is very easy. Let me know if you have any other questions. I rebuild a lot of steering columns.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Sorry keith, a picture is worth a 100 words
![]() Is the metal clip able to be mounted any place on the sleeve; I thought there was a hole, or an indent in the sleeve to locate it? If that is possible that would solve my problem! If it is a hole I suppose I could drill a new hole? With the bezel off, I can pull the sleeve towards the dash, disengaging the tabs on the plastice sleeve from the metal sleeve. But it will only re-engage in a place where the cable is slack, and doesn't start pulling until the shifter is about in drive. Cable is not broken, don't think it could stretch to the extent it would have to be to do what it is doing. Thanks for the feedback!
#5 | |
![]() The clip should just slip over the edge of the plastic sleeve; there are no idents, targets or holes which will locate it. Besides the cable being stretched out, the only other thing I could think of is it seems like there were some little tabs on the gage cluster that helped route the little cable. Make sure those are not broken off and that the cable is routed through them to achieve the desired motion (...going from memory here). K
78K & 79C Jimmys
gear marker pics
right marker holds the wire in the grove,some even have a wheel! look for the hole @ the edge
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 10-02-2013 at 02:31 PM. |
They like to break right there..
Thanks, Motornut.
So is there a slot in the plastic sleeve, and a threaded fastener gets shot through the clip once it's positioned? I'm afraid I don't remember that level of detail. K
78K & 79C Jimmys
yes it's a small screw,tightens on the back side of the clip
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
78K & 79C Jimmys
" not all trucks are created equal " lol
noticed the 88 tilt is different has a little v ,lines up with shifter handle Posted via Mobile Device
#11 | ||
That was what I meant, I need to put a picture up, to better explain what I am having problems putting into words!
Is the white washer looking thing a wheel? My first guess would be that is a repair (kit?) of some sort? Either way, it didn't stick out to me that part was broken, it seemed like the cable was functioning properly, just too much slack to get it started? Quote:
If I try to snap it in place in a postion that will line everything up, it won't attach all the way. The only way to get it "mostly" attached is to clock that sleeve off quite a bit; I think this is because of the 4 tabs (at least), there are only 2 left? Which I think the only solution is to replace that sleeve??? Replacing the column would probably be easier, excpet this column is in real nice shape; tilt knuckle is tight, chrome on the shifter is good, text/images on the wiper control wand in good shape. Truck has 6x,xxx miles so I would hate to replace the column!
