Old 10-04-2013, 08:48 PM   #1
GMCNUT
GMCNUT's Avatar
WTB: correct 1970 only T400 kickdown switch
Hey Guys - I have bought my first 69-72 truck and it is a 1970 CST short bed w/ factory #'s and date code matching 402 BB. I have come to realize that due to the addition of spark control that was not present on 1968-69 396 equipped trucks, 1970 402's came with a slightly different T400 kickdown switch - one that apparently does not have the "tangs" as used in 68-69, but instead must have bullet shaped prongs of some kind on it, because my kickdown wiring (pictured below) has the plug made for a different type connector than used on 68-69 switches.
So, does anyone have one of the 1970 only type kickdown switches I can buy?
Thanks in advance - Steve
GMCNUT is offline   Reply With Quote
Old 10-04-2013, 10:01 PM   #2
chewychevy67
Re: WTB: correct 1970 only T400 kickdown switch
i don't have one but here is a pic of it. I am not sure but i believe the overdrive 3 speed standard transmissions use this switch as well
chewychevy67 is offline   Reply With Quote
Old 10-05-2013, 12:37 PM   #3
GMCNUT
GMCNUT's Avatar
Thank you for the picture - now all the members who may have one can see the one I need now - Anybody got one of these?
Old 10-05-2013, 04:34 PM   #4
71 super
71 super's Avatar
I may have a spare, do you need the bracket as well? Not sure if the switch I have is good any way to check?
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-06-2013, 03:58 PM   #5
GMCNUT
GMCNUT's Avatar
No way to tell but installing it that I know of - I have a 69 switch and do not know if the bracket is the same or not, so I would probably want your switch w/ bracket in case something is different about it or unless you only have the spare switch itself....is your spare off a 1970 Chevy / GMC?
Old 10-06-2013, 06:50 PM   #6
71 super
71 super's Avatar
The spate is off 70 I will pull it out and send you some pics
Old 10-06-2013, 11:25 PM   #7
GMCNUT
GMCNUT's Avatar
Perfect - much appreciated!
Old 10-07-2013, 10:28 AM   #8
kaphillips
kaphillips's Avatar
here is a picture with the mounting bracket it appears to be different than the 69 kickdown switch mounting bracket.
kaphillips is offline   Reply With Quote
Old 10-10-2013, 12:50 AM   #9
GMCNUT
GMCNUT's Avatar
Wow Ken - Didn't take you long to find one after I told you they were different than 68-69 - you work faster than anyone I know
I need to get you to find my stuff and quit beating my head against a brick wall all the time....
you can't find factory power steering for a 60-62 torsion bar chevy / GMC can you? hahaha as lucky as you are you would probably find it in 3 days when I have been searching 3 years
Old 10-10-2013, 08:10 AM   #10
kaphillips
kaphillips's Avatar
Call me about the switch, I will be purchasing a lot of 70 parts in the the next 2-3 and that switch is in the lot. If my truck does not use this switch you might persuade me to sell it to you.
Old 10-10-2013, 11:17 AM   #11
kaphillips
kaphillips's Avatar
gmcnut check out this url for putting power steering on your 60-62 truck.
http://www.classicperform.com/power6066.htm
Old 10-10-2013, 11:29 AM   #12
kaphillips
kaphillips's Avatar
gmcnut, here is the guru of late model oem gm power steering systems. If he does not have it he can find it, although he is not cheap. Check him out his name is Jim home # 480-981-3096 or his cell is 602-751-0454. Hope this helps, and good luck on your search.
Old 10-14-2013, 01:04 AM   #13
GMCNUT
GMCNUT's Avatar
Thank you Ken - will call Jim tomorrow
