10-07-2013, 01:44 AM | #1 |
70 gmc drum to disc
(70 gmc) hey everyone, only my 4th time posting for info, i scanned the posts for a while but was unable to see a clear answer for a swap i want to do.i want to swap my manual drum front brakes to manual disc( i like the feel of a manual brake) i have a complete front end for a 71 with disc including crossmember and rear axles, can i bolt this crossmember right in to my truck complete using my dual reservoir master and proportioning valve (if im keeping manual brakes) and will the axles swap right in ????
thanks in advance!!!! |
10-07-2013, 02:14 AM | #2 |
Its a Truck Thing......
Re: 70 gmc drum to disc
I would use the master and prop valve off the manual disk set up. Everything else should bolt right up.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
10-07-2013, 06:58 AM | #3 |
blood type; Retumbo
disc and drum use different master cylinders. The master cylinder from a boosted truck will bolt right up to your firewall
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-07-2013, 08:45 AM | #4 |
For the rear axles, If you want to shoot me a PM, I'll help you measure and I can tell you for sure without having to take yours apart.
