10-07-2013, 12:12 PM | #1 |
Brake booster alignment question
I just installed the power brake adapter, booster and master cylinder to my 72' LWB truck. The brackets and booster went right in with no issues but when I mounted the master cylinder I spotted a problem. The nose of the master cylinder sits down instead of tipped back and upwards like every vehicle I have worked on. Any thoughts?
Thanks in advance. 88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
10-07-2013, 12:15 PM | #2 |
Re: Brake booster alignment question
I hate to be the first responder but I don't think it will be an issue.
The master cylinder is a pressure vessel, so the orientation (within reason) does not affect function and only impacts underhood packaging and the ability to add fluid. So - as long as you can hook the lines up, fill it with fluid and get the hood closed I think you're ok. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-07-2013, 12:52 PM | #3 |
Agreed, I don't think its a show stopper. Everything else looks good but I am confused as to why it would point downwards. Maybe some one on here who has done the conversion will chime in.
88
10-07-2013, 01:10 PM | #4 |
member #16
Check this thread, they are all like yours.
http://67-72chevytrucks.com/vboard/s...d.php?t=549556
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-07-2013, 01:20 PM | #5 |
Agreed. I haven't seen one on these trucks that is not tipped forward.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-07-2013, 01:26 PM | #6 |
Thank you gentlemen. I was searching the forum but that thread is the best. I didn't want to assemble anymore on it until I verified that the position is correct. Thanks again.
88
10-07-2013, 04:01 PM | #7 |
Mine leans forward as well
71 swb 350/4sp manual 5/7 static drop |
